Portable Optical Inspection System Built for High-Volume CNC Production
OASIS Inspection Systems, an innovator in precision measurement and optical inspection technology, has announced the commercial launch of the EDGE CORE, model a next-generation optical inspection system purpose-built for manufacturers operating CNC lathes and Swiss Screw CNC lathes in high-volume production environments.
Combining superior structural rigidity, reduced weight, true portability, and plug-and-play simplicity, the EDGE CORE delivers exceptional accuracy and precision at a price point that makes best-in-class inspection accessible to manufacturers of every size.
Engineered for Rigidity and Portability
The EDGE CORE is the result of a comprehensive re-engineering effort focused on delivering a more rigid, more durable platform without compromising portability. By leveraging advanced materials and a precision-optimized frame architecture, the system achieves greater structural stability than previous-generation inspection systems — all while weighing significantly less. The result is a shop-floor inspection solution that stays where it needs to be and goes wherever production demands it.
Ready to Inspect in Minutes
The EDGE CORE unit ships complete and pre-configured — operators can unbox, connect, and begin inspecting within minutes. There are no complex installations, no lengthy calibration procedures, and no specialized IT setup required. The system features the same intuitive, easy-to-navigate interface that OASIS users already know, ensuring a seamless transition and minimal training overhead for shop floor personnel.
“We designed this product so that a manufacturer can take it out of the shipping box, set it next to the machine, and start generating meaningful inspection data immediately,” said Tunji Taiwo., President at OASIS Inspection Systems. “That kind of time-to-value is something our customers have been asking for, and we delivered it.”
Proven Measurement Performance for Turned Parts
Built on the same proven optical inspection technology that has made OASIS Inspection Systems a trusted name in precision measurement, the EDGE CORE delivers the measurement accuracy and repeatability that turned-part manufacturers demand. Whether inspecting tight-tolerance components off a CNC lathe or managing high-volume quality checks on a Swiss Screw line, the system produces reliable, consistent results that operators and quality engineers can trust — shift after shift, batch after batch.
Affordable Access to Optical Inspection
Affordability has been a cornerstone of the OASIS EDGE CORE development. The system is priced to make precision optical inspection financially accessible across the full spectrum of manufacturing operations — from small job shops to large-scale production facilities. Combined with its rapid deployment capability and immediate productivity impact, customers can expect a faster return on investment than with comparable systems on the market.
OASIS EDGE CORE key benefits:
- High-accuracy optical measurement ideal for turned parts
- Rigid frame architecture for superior structural stability and measurement repeatability
- True portability — move the system to the machine, not the part to the lab
- Significantly lighter than comparable inspection systems — easy to reposition across the production floor
- Plug-and-play out of the box — operational in minutes
- Intuitive interface requiring minimal operator training
For more information: www.oasisinspectionsystems.com
