Closing The Loop with Shop Floor Coordinate Metrology
For much of the CMM’s history, dimensional measurement has remained a downstream quality function, performed in environmentally controlled inspection rooms after parts have left the production line. Today, that model is changing. Manufacturers increasingly expect metrology systems to operate within the manufacturing process itself, providing rapid, traceable measurement data that supports statistical
process control, adaptive machining and automated production decisions. As the distinction between inspection and manufacturing continues to blur, production metrology is emerging as a critical enabler of closed-loop manufacturing. Renishaw’s new Equator X exemplifies this shift by combining the high throughput of comparative gauging with the flexibility and traceability traditionally associated with coordinate measuring machines.
Metrology News sat down with Dan Skulan, General Manager at Renishaw, Inc., to discuss the evolution of shop-floor metrology, the convergence of comparative and absolute measurement technologies, and how the Equator X is helping redefine the role of coordinate metrology in modern manufacturing.
Q: Coordinate metrology has traditionally been separated from production because of concerns over environmental stability and measurement uncertainty. What developments in machine architecture, sensing technology and software compensation have made high-accuracy shop-floor metrology a practical reality?
A: Modern inspection devices must contend with the harsh environments found on manufacturing floors. Extreme and rapidly changing temperatures, coolant and swarf on parts, and production staff who may have limited experience with sensitive metrology equipment all present challenges. To address these issues, shop‑floor devices typically measure and adjust for temperature changes. Sensors directly measure air temperature and part temperature to compensate results using the coefficients of thermal expansion for both the CMM structure and the part.
Traditional bridge‑style CMMs have been replaced by gantry‑style systems that position linear axis guides, drives, and scales high off the floor under protective bellows. Part preparation on the CNC includes breaking sharp edges and using directional coolant to remove swarf and chips. Additional cleaning methods, such as ultrasonic baths, can remove micron‑sized particles to further prepare tight‑tolerance parts for inspection. Simplified programming tools tied directly to CAD/CAM software — and increasingly AI — allow production staff to program measurement devices with minimal metrology background.
Beyond environmental hardening and improved part preparation, several developments have made high‑accuracy shop‑floor metrology practical and repeatable. Dynamic thermal compensation, evolved mechanical architectures, high‑speed scanning probes, CAD‑driven programming, and automated feedback loops all contribute to stable, traceable measurement directly at the point of manufacture.
Q: Industry has increasingly recognised that measurement should be viewed as a process-control function rather than simply a quality verification step. How do you see coordinate metrology evolving within closed-loop manufacturing strategies, and what role should dimensional data play in controlling process capability?
A: Final inspection of a part is still valuable for comprehensive evaluation of part quality, but it is a very costly way to make good parts. By the time a part is completed and presented to a laboratory CMM, substantial work‑in‑process is either running at risk or the process remains idle — both costly outcomes. Increasingly, manufacturers incorporate measurements during each stage of the manufacturing process. These measurements verify feature conformity after each stage. For example, a turned part can be inspected before moving to a milling machine so that non‑conforming parts are not further processed.
The real value comes from direct feedback of measurement data to adjust the process. Machining is done on the positive material side of a tolerance, measured, and directly fed back to control tool depth and location in the CNC.
Closed‑loop manufacturing shifts coordinate metrology from a downstream check to an active control mechanism. Dimensional data now steers machining decisions in real time, stabilizes processes, prevents value‑added operations on bad parts, and enables adaptive machining.
Q: Equator X combines comparative gauging with the capability to perform traceable absolute coordinate measurements. Traditionally these have been regarded as two distinct metrology disciplines. What engineering challenges had to be overcome to successfully combine both approaches within a single platform?
A: To understand the engineering challenges that the Equator X overcomes, it’s important to first understand why the original Equator relied on comparative measurement. Traditional CMMs require full volumetric error mapping using laser interferometry. Once mapped, the machine applies this error map during measurement, and with thermal compensation, this works well for slow touch‑trigger probing or low‑speed scanning. At higher scanning speeds, however, the CMM structure bends and twists during acceleration and deceleration, causing the stylus tip to deviate from the mapped geometry. This phenomenon — called non‑transduced motion — breaks the relationship between the probe tip and the error map, making high‑speed scanning inaccurate.
The original Equator solved this by using a highly rigid parallel‑kinematic structure capable of repeating position at the micron level even at scanning speeds around 250 mm/sec — roughly ten times faster than a typical CMM. Instead of relying on a volumetric error map, it used a master part measured at 20°C in a lab. By scanning the master at full speed, the Equator created a high‑density local error map “within the skin” of the part. This allowed the system to achieve CMM‑level accuracy at high speed and to re‑master whenever temperature changed, making it ideal for high‑volume, low‑changeover production.
Equator X advances this concept by moving to a hexapod architecture with six independent drive struts and six isolated encoders. This structure directly measures the probe’s 3D position and orientation without non‑transduced motion, even under dynamic loads. The machine is fully volumetrically error‑mapped, enabling absolute measurement at 250 mm/sec scanning speeds — something traditional CMMs cannot achieve. It can also operate in comparative mode at 500 mm/sec and can generate its own master file automatically.
Equator X combines two historically incompatible metrology philosophies by decoupling actuation from measurement, distributing loads symmetrically, and implementing dual calibration strategies.
Q: Comparative gauging has always offered exceptional throughput, while conventional CMMs have delivered flexibility, traceability and comprehensive feature evaluation. Does Equator X fundamentally change this long-standing trade-off, and how do you expect manufacturers to rethink their inspection strategies as a result?
A: Equator X fundamentally changes the historical trade‑off between throughput and traceability. Traditional comparative gauging delivers speed but sacrifices flexibility and traceability, while CMMs deliver traceability but at the cost of throughput. By combining a hexapod’s rigidity with isolated encoder feedback and full volumetric error mapping, Equator X provides absolute measurement at high scanning speeds and comparative measurement at even higher speeds.
This means manufacturers no longer need separate systems for high‑volume production and low‑volume, high‑mix work. Equator X delivers:
– CMM‑like traceability in absolute mode
– Gauging‑level throughput in comparative mode
– Seamless switching between modes
– Automatic master‑file generation
Equator X collapses the traditional trade‑off: throughput and traceability now coexist in a single platform.
Q: Modern manufacturing increasingly demands that measurement data feeds directly into machining offsets, adaptive control and statistical process monitoring. How has Equator X been designed to support these digital workflows, and where do you see the greatest opportunities for closed-loop process optimization?
A: By being a high‑speed, fully traceable measurement system located directly beside the CNC machine, process data can be maintained within the takt time of production. This enables direct machine feedback of work and tool offsets, allowing the process to adapt to changing raw material, tooling wear, and thermal conditions.
Equator X includes a state‑of‑the‑art digital interface called Renishaw Central, which provides the central data conduit between measurement and machining. It can accept data from any measurement device (not just Renishaw) and any CNC, and provide it to plant‑wide dashboarding systems. It also provides direct feedback to CNCs with a programmable smoothing algorithm that averages and adjusts feedback so process changes occur gradually and predictably.
Equator X enables real‑time offset feedback, adaptive machining, unified statistical monitoring, and digital traceability.
Q: Measurement throughput is often discussed alongside accuracy, but repeatability, reproducibility, thermal stability and uncertainty are equally critical on the shop floor. How have these competing performance requirements influenced the design philosophy behind Equator X?
A: Equator X is uniquely designed to provide optimum performance directly on the shop floor. Using a hexapod design with a floating metrology frame, it offers superior repeatability compared to traditional CMM structures. The two modes of operation — absolute and comparative — directly address low‑volume/high‑mix and high‑volume/low‑mix production, respectively.
In absolute mode, it incorporates air and part temperature sensors to maintain accuracy over typical shop‑floor temperature ranges at scanning speeds of 250 mm/sec.
In comparative mode, it benefits from rapid mastering for instant temperature normalization and scanning speeds of 500 mm/sec.
Equator X balances competing metrology requirements by separating motion generation from measurement, using symmetric hexapod geometry, implementing dual calibration strategies, and applying real‑time thermal compensation.
Q: As manufacturers increasingly adopt Model-Based Definition (MBD), digital twins and standards such as QIF, metrology systems are becoming integral nodes within the digital thread. How do you see shop-floor coordinate metrology evolving to support these emerging data-centric manufacturing environments?
A: Part designers, CAD/CAM vendors, and inspection software companies are doing considerable work to support the insertion and use of Model‑Based Definition (MBD). Tools such as PMI enable rapid programming of inspection features. Many modern inspection platforms can create routines directly from this data. Renishaw’s Modus software does this, and Renishaw’s I++ Server control on Equator and Agility platforms allows open‑architecture integration so that leading metrology software can drive Renishaw systems directly. This makes MBD accessible to a wide range of users.
Regarding digital twins, it is critical that software models have accurate information about the mechanical systems they simulate. Non‑transduced errors do not appear in software simulations, so measurements must be taken on systems that move in known, traceable ways.
Inspection outputs using QIF are standard and can be provided to plant‑wide smart‑manufacturing systems like Renishaw Central — not only from inspection devices but also from CNC machines.
Shop‑floor metrology will increasingly support MBD by reading PMI natively, auto‑generating inspection routines, and integrating with open architectures like I++. Digital twins will rely on metrology systems that provide traceable, deformation‑free motion data. QIF will unify measurement outputs across devices, CNCs, and analytics platforms.
Q: Manufacturers are increasingly seeking flexible inspection platforms capable of supporting both high-volume production and shorter product lifecycles with frequent changeovers. How does Equator X address these conflicting requirements, and where do you believe it delivers the greatest advantage over traditional production metrology solutions?
A: Equator X supports both high‑volume production and short product lifecycles by combining high‑speed comparative gauging with traceable absolute measurement in a single platform. Comparative mode provides gauging‑level throughput at 500 mm/sec with rapid mastering for thermal stability. Absolute mode delivers CMM‑like flexibility at 250 mm/sec with full volumetric mapping.
Because Equator X can generate its own master file and supports CAD‑driven programming, changeovers require minimal setup time. The system can run high‑volume parts during peak production and then transition to low‑volume, high‑mix work without reconfiguration.
Q: Looking beyond today’s manufacturing environment, do you believe the distinction between production equipment and coordinate metrology will continue to disappear? What developments in automation, AI-assisted inspection, autonomous process control and intelligent manufacturing do you expect will define the next generation of production metrology?
A: Measurements are moving from the quality lab to the shop floor at a rapid pace. Higher‑speed systems like Equator X provide the ability to control processes in real time. Renishaw works consultatively with manufacturers to incorporate advanced technologies for process feedback near the machine, such as Equator X, but in high‑value operations these measurements are increasingly being made directly in the CNC machine. By incorporating volumetric machine calibration, rapid setups, and in‑process metrology, many measurements are now done with high precision while the part is still in the machine.
Traditional CNC probing is being enhanced with scanning capability and even surface‑finish measurement. These process‑control tools will be increasingly required to support automation driven by an aging workforce and a shortage of new talent entering manufacturing. We are also seeing increased use of AI to write programs and provide oversight to production operations. These new tools rely on accurate data throughout to make informed decisions.
The distinction between production equipment and coordinate metrology is disappearing as machines gain real‑time geometric awareness. Next‑generation production metrology will be defined by integrated traceable measurement inside CNCs, dynamic machine calibration, high‑speed external metrology nodes like Equator X, unified digital ecosystems (MBD, QIF, digital twins), AI‑driven programming, and automation pressure from workforce shortages.
