The Future of Additive Manufacturing is NOT Additive Manufacturing Alone
For much of the last 30 years, the additive manufacturing (AM) industry has understandably concentrated on the additive process itself. Machines have become faster, resolution has improved, build volumes have increased. material portfolios have expanded, and software became more sophisticated.
All of this has mattered. But if the objective is genuinely to make polymer additive processes mainstream for production applications, improving the printer cannot be the end of the conversation. Manufacturers do not buy processes, they manufacture products, and this distinction is becoming increasingly important.
A printed polymer component rarely emerges from an AM system ready to enter service. It may require cleaning, curing, support removal, machining, surface finishing, inspection, measurement, or assembly. Each additional activity introduces handling, labour, scheduling, variability, and cost.
So while the additive process itself may be digital and automated, the complete manufacturing chain frequently is not.
This goes some way towards explaining one of the paradoxes surrounding AM. The technology has demonstrated extraordinary capability, yet outside certain high-value applications its transition into serial production has been slower than early predictions suggested.
The issue is not simply print speed, it’s the manufacturing system surrounding the printer.
The Automation Gap
It is perfectly possible to create a farm containing dozens or hundreds of additive machines. But multiplying automated printers does not necessarily create an automated factory.
If every build subsequently requires operators to remove parts, move them between processes, establish finishing operations, inspect components, and manage separate pieces of equipment, labour begins to scale alongside production.
At that point, one of digital manufacturing’s supposed advantages begins to disappear, and this creates what might be described as a cost-quality-labour bottleneck. Manufacturers want the flexibility associated with AM (no dedicated tooling, rapid design changes, geometrical freedom, and digital inventory), but they simultaneously expect the repeatability, dimensional control, productivity, and economics associated with established production technologies.
The future opportunity therefore lies in combining these characteristics rather than forcing manufacturers to choose between them.
Hybrid Should Mean More Than Two processes
Hybrid manufacturing is not itself a new idea, and additive and subtractive processes have been combined successfully for years. The more interesting development is the emergence of genuinely integrated manufacturing environments in which several complementary processes can operate as elements of one digital workflow.
A component might begin with one additive technology, receive material from another deposition process, undergo precision machining, move through cleaning or curing and ultimately be inspected, without each stage being treated as a separate manufacturing island.
That represents an important conceptual change. The printer stops being the centre of the manufacturing universe, and instead, additive becomes one highly valuable tool within a broader automated production platform.
This distinction matters because different manufacturing technologies are good at different things. Additive can create forms and material distributions that would otherwise be difficult or uneconomic. CNC machining can achieve critical surfaces, threads, and dimensional tolerances. Deposition technologies can introduce additional functional materials, and automated inspection can provide evidence that what has been manufactured corresponds to what was designed.
There is little industrial logic in asking one process to perform badly what another process already performs extremely well. The smarter approach is to orchestrate them.
From Prototypes to Hundreds of Parts
This also changes the economic conversation around AM. Nobody should seriously argue that hybrid additive systems will replace injection moulding for millions of identical polymer components. Injection moulding is extraordinarily effective at what it does. But there is an enormous manufacturing space between producing several prototypes and committing to high-volume tooling.
Imagine requiring 200, 500, or 1,000 repeatable parts during product development or early production. Traditional tooling may involve substantial capital expenditure and lead time. More importantly, a design change can make that tooling partially or completely redundant.
AM on its own removes the tooling requirement, but if hundreds of parts then require extensive manual finishing, inspection, and handling, its cost advantage can erode rapidly.
Automated hybrid manufacturing potentially expands the window in which digitally driven production is economically sensible. This is especially important for rapidly evolving products, customised devices, research-intensive sectors, defence applications, medical technologies, and high-mix manufacturing.
The objective is not additive at any cost, it’s manufacturing flexibility at an economically sensible cost.
Design Will Change as Well
There is another consequence. Most products today are designed around familiar manufacturing constraints. A designer knows, for example, what can be moulded, milled, cast, or assembled, and the product evolves accordingly.
Integrated hybrid manufacturing introduces a different design space. A component currently manufactured as five separate pieces because each requires a different process could potentially become one digitally produced component moving through several processes automatically.
Materials might be deposited only where required. Critical surfaces can subsequently be machined, and functional features can be introduced during the workflow rather than assembled afterwards.
This suggests that the next stage of Design for Additive Manufacturing (DfAM) may need to become something broader, namely “design for hybrid digital production” (DfHDP).
That will require collaboration between technology providers and early customers. Simply delivering a machine and expecting users to discover an entirely new manufacturing methodology themselves is unlikely to accelerate adoption. Application engineering, workflow development, and manufacturing knowledge will be as important as hardware.
Repeatability Changes Everything
Ultimately, industrial manufacturing depends on confidence. Making one excellent part is interesting. Making the 500th part with exactly the same characteristics and dimensions as the first is manufacturing.
This is why automation, measurement, and process traceability will become increasingly important within AM-driven production systems.
The significant breakthrough will not necessarily be another dramatic increase in printing speed, it may be the removal of all the interventions that occur before, during, and after printing and the creation of a digital thread that connects design, manufacture, finishing, and verification.
At XYZO, this is the direction in which we have been working, integrating additive, subtractive, deposition, post-processing, and measurement technologies within an automated hybrid manufacturing platform.
But the wider argument extends far beyond one company or one architecture. The AM sector has spent decades proving what additive manufacturing can do. Its next challenge is proving how efficiently, consistently, and economically these capabilities can become part of production.
That probably means becoming slightly less obsessed with the printer. Because the future of additive manufacturing may ultimately depend upon recognising that on its own, it was never supposed to be the factory.
Author: Kegan McColgan-Bannon, CEO, XYZO
For more information: www.xyzo.co
