High-Precision Motion Stage Advances Semiconductor Metrology
As semiconductor manufacturing advances toward smaller features, tighter tolerances, and higher throughput, precision motion systems play an increasingly important role in wafer inspection and metrology. The Physik Instrumente V-783 planar XY stage addresses these requirements with high positioning accuracy, excellent geometric stability, and fast, repeatable motion, from the global leader in motion control and positioning.
Unlike conventional stacked-axis designs, the V-783 uses an integrated planar XY architecture that reduces overall height while increasing bearing width and mechanical stiffness. This design minimizes geometric errors and supports precise, stable positioning across the full travel range, important for optical inspection, wafer mapping, and high-resolution surface measurements.
High Dynamics, Speed and Fast Step & Settle Reduce Cycle Times
Two ironless, three-phase linear motors drive each axis for maximum geometric performance. Ironless, direct-drive linear motors in combination with ACS NanoPWM control algorithm provide smooth, backlash-free motion and high dynamics. High acceleration and velocity enable rapid movement between measurement locations, helping reduce cycle times in automated semiconductor inspection equipment.
Key Performance Specifications:
  • 310 × 310 mm XY travel with a 360×360 mm clear aperture
  • 1 nm encoder resolution with incremental Sin/Cos or absolute BiSS-C feedback options
  • ±0.07 µm bidirectional repeatability for consistent measurement positioning
  • ±0.17 µm calibrated positioning accuracy for demanding metrology applications
  • Straightness and flatness down to 0.75 µm to minimize motion-induced measurement errors
  • Velocity up to 1 m/s and acceleration up to 10 m/s² for high-throughput inspection
  • 50 kg load capacity for integration of inspection optics, sensors, and measurement assemblies
Designed for Automated Semiconductor Metrology
The V-783 is particularly well suited for semiconductor inspection and metrology systems requiring precise movement between measurement points, including wafer surface inspection, optical metrology, defect detection, and dimensional measurement.
The optional absolute encoder provides immediate position feedback at power-up, eliminating the need for homing procedures. This reduces startup time and simplifies integration into automated semiconductor production equipment.
Hard-anodized aluminum construction supports cleanroom compatibility, while optional granite bases and XYZ configurations provide additional flexibility for machine builders developing high-precision metrology platforms.
Advanced Motion Control and System Integration
The V-783 integrates with PI’s A-81x and A-82x series ACS-based EtherCAT motion controllers. These controllers support synchronized multi-axis motion, integration into semiconductor automation systems, and PI’s PILOT algorithm for improved dynamic response while reducing motor currents and heat generation.
The V-783 combines nanometer-resolution positioning, high dynamic performance, and a compact planar architecture to meet the requirements of next-generation semiconductor metrology and wafer inspection equipment.
Applications and Industries Served
Semiconductor inspection and metrology such as wafer surface inspection, optical metrology, defect detection, dimensional measurement.
For more information: www.pi-usa.us
