The Metrology of Tomorrow – A Complete Digital Thread For Truly Universal Measurement
In metrology, before talking about technological advances or revolutionary new techniques, let’s start with the reality of everyday work.
Ask a metrologist where they lose their time, and they’ll tell you: re-entering tolerances that the design office has already defined, converting a CAD file the supplier can’t open, relearning a setting used once a quarter, searching for one function among hundreds of others …
This is the reality that should drive the innovations shaping the world of measurement over the next five to ten years. Progress will not come from measuring a few more microns precisely, but from measurement that fits as smoothly as possible into the company. But how do we get there?
Seamless Digital Chain
The Digital Thread and MBD (Model-Based Definition, which defines a product entirely in its 3D model rather than on a 2D drawing) are becoming concrete projects. The idea: quality information is created once, uniquely identified, and then follows the part from product definition through to inspection.
Until now, the dimensional tolerance has been stored inside the geometric feature: a Ø20 ±0.2 sits ‘in the cylinder.’ A single object mixes three needs: geometric and measurement data, definition and evaluation data for design, and quality data for tracking and exchange. Yet ISO and ASME now define dimensional tolerancing with its own capabilities and variants.
Identified, Traceable, Reusable Data
Standalone Dimensional Tolerance Object: Each tolerance has its own identifier, evaluation criteria and conformity evaluation data. It is kept separate from the geometric feature that carries the measurement. Imported identifiers are preserved, so tolerance remains identifiable and traceable.
Extended Support For QIF Format: QIF is an open, XML-based format that carries CAD data, characteristics, GD&T, inspection data and measurement results between applications and stakeholders. The goal goes beyond reading and writing files: retain the imported data, preserve its identifiers, add new information and pass it on in the same format, so nothing is re-entered along the Digital Thread. Two capabilities support this:
QIF import and Export Quality Check: Verifies syntax against the standard and detects anomalies, so the file is correct and as complete as possible.
Export of Points to be Measured: The customer includes predefined points in the file (for example, for a correlation process), and the subcontractor uses them to build the inspection plan.
Take one part, one working environment and several suppliers. The customer shares a single QIF file with CAD data, characteristics, dimensional tolerances and identifiers that match its own database. Subcontractors work directly on the CAD data in the file, with no conversion. Each dimensional tolerance carries its own identifier, and results return with their conformity evaluation data in the same format, processed automatically with no re-entry. Production information, dates and inspection frequency can be added, and because each tolerance is uniquely identified, you can locate the source of an anomaly or process drift.
By relying on standards and an open format, you choose longevity over a proprietary format, and you make metrology an active link in the chain rather than an isolated check at the end of the line.
Varied Equipment Fleet
Workshops very often combine CMMs, 5-axis heads, laser trackers, portable probes, non-contact sensors… The choice depends on the volume, precision and throughput of each part. There is no single technology, and there probably never will be.
But each new technology can create a silo: one more piece of software, duplicated inspection methods, adoption delayed because everything must be ‘reconfigured’…
Hardware-Agnostic, Universal Measurement System
Metrolog supports a wide range of machines, and has recently added support for three new measurement systems:
- Renishaw PH20 PLUS, a 5-axis touch-trigger CMM head, for deep bores, recessed geometries, large housings, and parts requiring several stylus lengths or orientations, with module changes within a single inspection sequence.
- API iLT with VProbe2, a laser tracker paired with a handheld tactile probe, for large jigs, fixtures and production equipment. The probe can touch features outside the tracker’s line of sight, all within the same workflow.
- Nikon APDIS MV5X, a compact non-contact laser radar, measures features and surfaces without a probe, targets or surface preparation, in portable, robot-mounted, fixed or near-line configurations.
Users can therefore choose the best technology for their part and your environment, and still program, run and analyze in the same software, preserving existing programs and know-how. In a world where hardware evolves quickly, software is the metrologist’s most stable element: it should absorb the change, not the user.
Teams With Specific Profiles
Teams are becoming more diverse, and each profile has its own needs. Software must absorb this diversity by offering interfaces that are simple to pick up. It can no longer afford settings spread across separate profiles and dialogs and bury its functions among hundreds of others, because this complexity often pushes companies to impose a single profile: a compromise for everyone but tailored to no one.
Software With Simplified Usability
Profiles & Workspaces Designed For End User: A Workspace is a named setup for a task, a user or a company standard, loaded in a single action. Experts define one approved setup per role and share it across stations and sites, instead of one all-in-one profile.
Everyday help directly With The Software: Users ask in natural language and get answers based on their own session, program and settings. They can ask why a result is not as expected: Copilot analyzes the session and feature dependencies to suggest a possible cause. It is read-only and never modifies the session, program or configuration.
In a profession where traceability and accountability for measurement are central, the most useful AI is the one whose behavior you can predict. And the time saved on configuring and searching gives time back to what matters: quality decisions. The metrology of the coming years will be judged less by what a system can measure than by how its data flows, how its hardware coexists, and how easily its users adopt it.
For more information: www.metrologicdcs.com
