AMiquam Advances In-Situ Defect Detection for Metal Additive Manufacturing
Swiss technology company AMiquam is reporting advances in the sensitivity of its in-situ eddy current (EC) inspection technology for metal additive manufacturing, demonstrating the detection of defects as small as 0.1 mm in thin-walled components produced using laser powder bed fusion (LPBF).
The developments, presented in a technical publication ahead of Formnext 2026, demonstrate the potential to inspect components layer by layer during the manufacturing process, rather than relying exclusively on post-build non-destructive testing to establish component quality.
The AMiquam approach uses an eddy current sensor integrated into the recoater assembly of an LPBF machine. As the recoater moves across the build platform, the sensor scans each newly deposited layer, recording electromagnetic signals that can reveal indications associated with internal defects. The inspection data is subsequently mapped to the component geometry, allowing detected anomalies to be automatically located and reported.
Detecting Defects Down to 0.1 mm
One of the most significant results concerns the inspection of thin-walled structures used in additively manufactured heat exchangers.
Using a 316L stainless steel test specimen with a wall thickness of 0.7 mm, AMiquam demonstrated the detection of five artificially introduced holes ranging from 0.1 to 0.5 mm in diameter. Both through-holes and blind holes produced distinct peaks in the eddy current signal, with even the smallest 0.1 mm indication clearly distinguishable from background signal variations.
The measurements were collected across approximately 127 layers, with each hole producing a corresponding signal peak as the build progressed.
The results indicate the potential for inspecting complex structures, including triply periodic minimal surface (TPMS) heat exchangers, where internal channels and thin walls can make conventional post-process inspection challenging.
AMiquam also describes a concept for generating an inspection certificate containing information such as material, layer coverage, detection limits and detected indications. This would provide a structured record of inspection data generated during manufacture, although the certificate presented in the publication is an illustrative example rather than an actual component certification.
Inspection of Aeroengine Blade Structures
A second application focuses on LPBF-manufactured aeroengine blades, where different laser scanning strategies produce distinct microstructures within the same component.
The blade design incorporates a conformal laser scanning strategy in the surface skin, while the bulk material is manufactured using a conventional chessboard scanning approach. These different processing strategies influence the resulting microstructure and, consequently, the eddy current signals generated during inspection.
AMiquam reports a defect detection capability of approximately 0.2 mm within the conformal skin. In the bulk material, the detection threshold is approximately 0.5 mm, where variations in microstructure generate additional signal fluctuations that can make smaller indications more difficult to distinguish.
The company notes that detection sensitivity depends on several factors, including material characteristics, laser scanning strategy and component geometry. Optimising laser strategies could potentially improve detection performance in the bulk regions.
Automated Defect Location and Layer-by-Layer Inspection
Beyond detecting defects, the technology is designed to establish their precise location within the manufactured component.
Eddy current signals recorded during each recoating operation are mapped onto the part geometry. Software then automatically identifies indications exceeding predefined detection thresholds and assigns their positions in X, Y and build-layer coordinates.
This approach provides manufacturers with more than a general indication of process instability. It offers spatial information that can help identify where defects occur within a component and support subsequent investigations into their origin.
By capturing inspection data throughout the build, manufacturers could also gain earlier insight into potential quality issues, rather than discovering them only after the component has been completed.
Moving Quality Assurance Closer to the Manufacturing Process
The latest results demonstrate the potential for eddy current inspection to become an integral part of metal additive manufacturing quality assurance. In particular, the ability to inspect every layer and identify relatively small defects could be valuable for applications involving complex internal geometries and safety-critical components.
For aerospace, energy and medical manufacturing, where component qualification and traceability are important considerations, the ability to generate inspection evidence during production could help reduce dependence on time-consuming post-build inspection procedures.
However, detection thresholds remain dependent on component geometry, material and manufacturing parameters, and the reported results should be considered application-specific rather than universal performance limits.
AMiquam’s work highlights how established non-destructive testing principles can be adapted for in-process inspection, potentially bringing defect detection, process understanding and quality documentation closer to the point of manufacture.
For more information: www.amiquam.ch
