Formnext 2026 Highlights Advances in AM Quality and Process Control
New developments in in-situ inspection, artificial intelligence, process simulation and production data management demonstrate how additive manufacturing suppliers are addressing the challenges of repeatability, traceability and industrial-scale production.
The recent Formnext 2026 exhibition showcased a growing range of technologies aimed at improving the quality, consistency and production control of additive manufacturing (AM).
While improvements in printing speed, productivity and material capabilities remain important themes, increasing attention is being directed towards technologies surrounding the printing process itself. New inspection systems, in-situ monitoring platforms, artificial intelligence (AI) software and manufacturing execution systems (MES) are helping manufacturers identify process deviations, reduce failed builds and establish more reliable quality records.
The developments reflect the transition of additive manufacturing from a technology primarily associated with prototyping and specialist production towards repeatable, validated manufacturing suitable for serial production. In this environment, understanding how a component was manufactured, monitoring what happened during the build and verifying finished-part quality are becoming increasingly important.
Measuring The Build Layer by Layer
One of the significant developments comes from Phase3D, which presented a new generation of its Fringe Inspection system for metal laser powder bed fusion (LPBF).
Rather than relying solely on conventional camera images to identify irregularities, Fringe Inspection uses structured light to produce calibrated, quantitative three-dimensional measurements of the powder bed and melted surface throughout the build process.
The system projects structured light patterns across the powder bed and analyses their deformation to reconstruct the surface in three dimensions. Measurements taken before and after laser exposure allow users to identify variations in powder distribution, surface height and layer formation.
An important capability is measuring actual layer thickness by comparing successive surface measurements. This provides information about deviations from intended layer formation, potentially identifying problems that might otherwise remain undetected until subsequent inspection.
Phase3D has also introduced User Profiles within its Fringe Operator software, allowing users to save application-specific inspection configurations, including measurements, acceptance thresholds and alerts. This makes inspection criteria developed during process qualification repeatable across production machines.
The new hardware incorporates a purpose-built projector, onboard computing and a passively cooled aluminium housing, replacing commercial components used in earlier configurations. This is intended to simplify integration by AM machine manufacturers.
AI-Based Monitoring Targets Early Defect Detection
Lortek’s Digital AM Core platform combines machine vision, melt-pool monitoring, AI and real-time geometric process tracking.
The platform is designed to detect manufacturing anomalies during production rather than relying exclusively on post-build inspection.
High-resolution images are captured following powder deposition and laser melting. AI algorithms analyse these images to identify potential defects including spatter, warping, hot spots and recoater lines.
Digital AM Core also incorporates AI-supported melt-pool monitoring using photodiode data. Energy emissions from the melt pool are measured and analysed in real time to identify deviations from expected process behaviour and generate alerts.
Combining image-based inspection and melt-pool analysis provides a more comprehensive picture of process stability, particularly as powder distribution, recoater performance, laser interaction and thermal conditions can all influence the resulting component.
Comparative Inspection and In-Situ Monitoring
Additive Assurance demonstrated its AMiRIS in-situ quality monitoring platform, designed for LPBF production.
The system uses near-infrared sensing and automated analysis to compare manufacturing builds and individual parts against known-good reference data. The objective is to identify anomalies, establish whether a build is following an accepted process and generate traceable evidence of manufacturing quality.
AMiRIS is available in configurations for standard and large-format metal AM systems, with an integrated version also developed for machine manufacturers.
Comparing builds against established references is particularly relevant to serial production, where manufacturers need to demonstrate that successive production runs remain within defined process limits.
In-situ monitoring does not automatically replace final component inspection, but it provides additional information about manufacturing conditions that can help direct subsequent inspection and support qualification decisions.
AI Analyses Existing Machine Camera Data
Icelandic technology company Euler demonstrated an alternative approach to monitoring metal AM builds, using layer images already captured by many LPBF machines.
Its software analyses existing machine camera images using deep-learning AI models to identify potential defects including spatter, warpage and streaking. Tracking how anomalies develop between successive layers helps identify problems early enough for operators to intervene.
An important advantage is that the approach does not require additional sensors on compatible machines.
Euler also demonstrated improved 3D visualisation, creating representations of builds with defect heatmaps that allow engineers to examine anomalies at individual layers without sharing the original CAD design.
Another development is Euler MCP (Model Context Protocol), which connects build information to AI assistants. Users can ask questions about builds, detected defects and machine performance, with the assistant able to open the relevant build and layer.
The company has also introduced batch analysis to compare multiple builds and identify differences in defect characteristics.
Simulation Aims to Prevent Defects Before Printing
While in-situ monitoring identifies problems during production, PanOptimization demonstrated PanX, a physics-based thermo-mechanical simulation platform designed to predict metal AM build behaviour before manufacturing begins.
The software analyses complete parts and builds, taking account of process parameters, component constraints and printer characteristics. Its objective is to predict potential problems before they result in failed components or parts outside dimensional tolerances.
This is particularly important in metal LPBF, where thermal stresses, distortion and residual stresses can affect component geometry and dimensional accuracy.
PanX is already being used by Nikon SLM Solutions, illustrating the growing integration of simulation into industrial AM workflows.
Predicting potential problems before a build starts can reduce the number of physical trials required to establish a stable manufacturing process.
Connecting Production Data to Component Quality
The increasing availability of monitoring and inspection data creates a requirement for systems capable of bringing information from different stages of production together.
Software company amsight demonstrated its quality management approach for serial additive manufacturing.
Its software connects information from powder materials, printing, post-processing and inspection into a consolidated quality record. Capabilities include QR-code-based powder tracking, automated data capture, reporting, traceability and statistical process control.
The objective is to establish relationships between the materials used, machine operating conditions, manufacturing parameters and inspection results obtained from finished components.
This is particularly relevant to powder-based AM processes, where material batch history, powder reuse and blending can influence manufacturing consistency.
Rather than replacing existing MES, ERP or quality management systems, amsight is designed to complement these platforms by providing a dedicated quality data layer for additive manufacturing.
Oqton Expands Production Management and Traceability
Oqton has launched MOS 2.0, the latest generation of its Manufacturing Operating System for additive manufacturing.
The platform can be deployed in the cloud or on-premises and combines manufacturing execution, order management and digital warehouse capabilities.
New features include production scheduling alerts, operator work instructions, digital checklists, non-conformance management and powder management.
Of particular relevance to quality assurance are digital part passports, which bring together production, material and quality information associated with individual components.
Powder management tracks material lots from receipt through successive builds, linking the powder used to the resulting components. Operators can also identify non-conforming parts or batches and place them on hold for review.
Oqton has strengthened integration across its software portfolio. Its 3DXpert build preparation software passes build files, printing parameters and build reports into MOS, while AMVero adds in-process monitoring data and fleet management capabilities.
The result is a more connected digital thread extending from build preparation through manufacturing execution and finished-part documentation.
Greater Control Over Printing Process
Other developments at Formnext demonstrate how software integration and access to machine parameters are giving manufacturers greater control over the printing process itself.
Dyndrite and Xact Metal have announced what they describe as the first commercially available full G-code toolpath integration for LPBF machine manufacturers.
The collaboration gives Dyndrite’s LPBF Pro software direct access to the scanning systems of Xact Metal printers, allowing users to control native arc commands and other scanning instructions.
The integration is initially available for the XM200G and XM200G µHD systems, with the XM300G expected to follow.
The development gives users greater freedom to optimise scanning strategies and printing instructions rather than being restricted to predefined machine settings.
Separately, Fives AddUp is working with Dyndrite to integrate its FormUp 350 metal AM system into LPBF Pro, allowing users to generate build files within the Dyndrite environment.
Fives AddUp has also announced a partnership with ADAXIS to improve programming and process control for its BeAM directed energy deposition systems.
Integration with ADAXIS’ AdaOne software will support multi-axis toolpath generation, machine movement simulation and manufacturing programming, with further development planned around modelling physical phenomena associated with laser powder deposition.
These developments reflect the growing importance of controlling the actual instructions sent to additive manufacturing machines, rather than simply optimising component geometry.
Towards Integrated Quality Assurance
The developments at Formnext 2026 illustrate how manufacturers are approaching quality assurance as an increasingly integrated part of additive manufacturing.
Historically, much of the emphasis has been on inspecting finished components using dimensional measurement, CT scanning, material testing and other non-destructive evaluation techniques. While these methods remain essential, they do not necessarily provide a complete understanding of what happened during manufacturing.
The latest technologies extend measurement and monitoring capabilities into the build itself. Simulation can predict problems before production begins, in-situ monitoring can identify process deviations, and AI can analyse large volumes of machine data to identify patterns that might otherwise go unnoticed.
Meanwhile, manufacturing execution and quality management software can connect this information with material history, production parameters and final inspection results.
The challenge will be ensuring that these different sources of information produce meaningful, validated evidence of component quality. Detecting an anomaly does not necessarily establish that a component is defective, just as an apparently stable process does not guarantee that every finished component meets its specification.
Ultimately, the value of these developments will depend on how effectively manufacturers can correlate process data with actual component characteristics and establish reliable acceptance criteria.
As additive manufacturing continues its transition towards industrial serial production, the ability to measure, monitor and control the manufacturing process is becoming just as important as the capabilities of the 3D printer itself.
Editor
