Metrolog Extends Digital Quality and Tolerance Analysis Capabilities
Metrologic DCS, part of Sandvik Group, has announced the release of Metrolog V26, its universal metrology software, and 3DCS 8.4, its tolerance analysis and variation simulation software. The new versions help quality and engineering teams reuse quality data without re-entry, measure each part with the most suitable system in a single environment, and make tooling, datum and assembly decisions earlier, with more evidence.
Complete Digital Thread and Universal Measurement
Quality data created once, carried without re-entry: Until now, Metrolog stored dimensional tolerances inside the geometric feature, mixing measurement, evaluation and tracking data in one object. Metrolog V26 introduces a standalone Dimensional Tolerance object: each tolerance has its own identifier, evaluation criteria and conformity data. Identifiers of imported data are preserved, so every tolerance stays uniquely identifiable and traceable. The object follows ISO GPS and ASME standards and is designed to follow their future revisions. New 3D expert views make deviations and anomalies easier to analyze.
One file, one set of identifiers, for every supplier: Sharing one part with several suppliers usually means manual transfers, file conversions and a risk of errors. With Metrolog, the customer shares a single QIF file, subcontractors work directly on the CAD data, and results come back in the same file, processed automatically. V26 adds two QIF capabilities: a quality check on import and export, which verifies syntax against the standard and detects anomalies, and the export of points to be measured, so subcontractors can build their inspection plan from predefined points.
“Quality data should be created once and trusted everywhere. Metrolog V26 brings that closer: one tolerance, one identifier, from the design office to every supplier, on any measurement system” comments Sylvain Anselmetti, Product Manager, Metrologic DCS.
More Measurement Choice – One Consistent Workflow
Manufacturers combine several measurement systems, and every unsupported device means a separate application or a duplicated inspection method. Metrolog V26 adds three new systems that users program, run and analyze in the same environment as their existing equipment:
Renishaw PH20 PLUS: 5-axis touch-trigger CMM head for deep bores, recessed geometries and large housings, with module changes within one inspection sequence.
API iLT with VProbe2: laser tracker with a handheld tactile probe, to measure features outside the tracker’s line of sight on aerospace structures, tooling, jigs and fixtures, in the same workflow.
Nikon APDIS MV5X: compact non-contact laser radar that measures features and surfaces directly, without probes, targets or surface preparation, in portable, robot-mounted, fixed or near-line setups.
Productive Fom Day One
Upcoming soon, Profiles & Workspaces give each role a ready-made, approved setup, and Metrolog Copilot answers users’ questions in natural language, so new and occasional users are productive from day one.
More Insight From Existing Simulation Results
All three new 3DCS capabilities build on simulation results a team already has, so engineers gain insight without running more simulations.
Earlier insights into tradeoffs: Gap, flush and alignment requirements share parts, datums and tolerances, so improving one can degrade another, and conflicts are often found only after tooling is built. Correlation Analysis pairs the measurement values from existing Monte Carlo trials and shows which measurements change together, so these tradeoffs are visible before tooling is ordered.
Faster focus in large models: In large models, tolerances that affect the same measurements sit far apart in the Geofactor table, which shows how much each tolerance contributes to each measurement. Bandwidth Minimization reorders the table so tolerances and measurements that influence each other sit side by side, with every value unchanged and traceable. Combined with Correlation Analysis, it shows both which measurements move together and which part variations drive them.
Evidence from the edges of the distribution: Most results fall near the center of a distribution, but the outer edges, or tails, matter most for critical functions and for High Risk or High Safety characteristics. Extreme Risk Analysis lets engineers examine these tails before committing to tooling and production and bring that evidence into FMEA and Control Plan discussions.
“The most expensive tolerance problem is the one found after tooling is built. 3DCS 8.4 gives engineers more evidence from the simulations they already run, so they can decide earlier and with more confidence” comments Steve Bannash, Product Director, Metrologic DCS.
For more information: www.metrologicdcs.com
