From AI-Assisted Inspection to AI-Native Metrology
Artificial intelligence is rapidly changing the role of metrology within manufacturing. What began as the application of AI to individual inspection tasks is evolving into something considerably more significant: measurement systems designed around artificial intelligence, data and increasingly autonomous decision-making.
This transition from ‘AI-assisted inspection to AI-native metrology’ could become one of the most important developments in industrial measurement. Rather than simply using AI to improve an existing inspection process, the longer-term opportunity is to design measurement, interpretation and decision-making as part of a single intelligent workflow.
Examples of this transition are already emerging across industrial inspection. ZEISS, for example, has integrated AI-based defect detection into its INSPECT X-Ray software through its ZADD Segmentation application, while KEYENCE is combining conventional rule-based vision inspection with AI-based inspection within its VS platform. Nikon has also introduced automated microscopy incorporating AI-powered image analysis. These developments demonstrate that AI is already moving beyond experimentation and into practical quality-control applications.
From Automation to Intelligence
Traditional automated inspection typically follows a predictable sequence. A component is presented to the measurement system, a predefined inspection routine is executed, results are compared with specifications, and a report is generated.
AI-assisted inspection improves this process by introducing capabilities such as automated feature recognition, image classification, defect detection and adaptive inspection. These applications can reduce programming requirements and help systems deal with greater variation in components and manufacturing conditions.
KEYENCE, for example, describes its AI vision technology as an extension of conventional machine vision, allowing AI models to learn acceptable part appearance and reduce the need for continual manual adjustment of inspection logic. Its VS platform allows traditional rule-based inspection and AI inspection to operate together.
However, the underlying architecture remains essentially the same: the inspection system performs a predefined task and AI assists with one or more elements of that process.
AI-Native Metrology – A Different Approach
Here, artificial intelligence becomes a fundamental component of the measurement architecture. The system can potentially combine sensor data, CAD models, historical measurements, manufacturing information and contextual knowledge to determine not only what should be measured, but potentially how it should be measured and what the results mean.
The industry is not yet at a point where this vision is commonplace, but the direction of travel is becoming clear.
AI Is Already Transforming Defect Detection
One of the most mature applications of AI in metrology is automated defect detection.
ZEISS’s ZADD Segmentation uses machine learning to detect, segment and evaluate defects in industrial CT data. This is particularly significant because CT inspection can generate complex datasets containing noise and artefacts that make automated defect identification difficult using conventional image-processing techniques.
ZEISS says its system can use pre-trained or customised AI models to identify defects such as porosity and inclusions, with applications including castings, electric-motor stator hairpins and electronic components. In specific applications, the company reports inspection-time reductions of up to 75 percent for castings and approximately tenfold faster inspection of medical implants compared with traditional analysis.
This represents an important step beyond simply automating a measurement routine. The AI is interpreting complex three-dimensional measurement data and identifying features that would otherwise require significant human analysis.
From Detecting Defects to Understanding Them
The next step is arguably more important: moving from defect detection to defect understanding.
A conventional inspection system may identify that a feature is outside tolerance. An AI-enabled system can potentially go further by identifying relationships between that measurement and other process variables.
The objective is therefore not simply to determine whether a component is good or bad, but to understand why a variation occurred and what action should be taken.
This is where metrology becomes increasingly connected to manufacturing intelligence.
ZEISS is already positioning AI and connected quality data in this direction. At Hannover Messe 2026, the company highlighted the combination of precise quality data, automated quality processes, digital twins and AI-based analytics for process optimisation.
Automation of the Complete Inspection Workflow
Another important development is the application of AI across more of the inspection workflow rather than a single inspection task.
Nikon’s ECLIPSE LV100AMS automated microscope, launched in 2026, combines automated inspection with AI-powered image analysis. Nikon describes the system as automating the workflow from image acquisition through analysis, with the objective of improving consistency and inspection speed while reducing human error.
This illustrates an important distinction. AI is no longer necessarily being used simply to classify an image. It can form part of a broader automated measurement process in which acquisition, analysis and evaluation are increasingly integrated.
That is an important stepping stone toward AI-native metrology.
Closing the Measurement–Manufacturing Loop
The ultimate opportunity for AI-native metrology is to move measurement from an information-generating activity into an active component of process control.
Consider a machining operation producing a critical aerospace component. An inspection system identifies a gradual dimensional shift across a series of components. Rather than simply recording the deviation, an intelligent metrology system could recognise the trend, compare it with historical data and identify a likely relationship with tool wear.
The information could then be communicated directly to the manufacturing system.
The process might automatically compensate for the developing variation, request a tool change, adjust machining parameters or alert an operator.
The resulting architecture becomes:
Manufacture → Measure → Analyse → Predict → Correct → Manufacture
This is the essence of closed-loop manufacturing, but AI has the potential to make the loop substantially more intelligent and adaptive.
The Importance of Data
AI-native metrology also reinforces a point that has become increasingly important throughout the evolution of digital manufacturing: measurement data is an industrial asset. A single inspection result has limited value in isolation. Thousands or millions of measurements collected over time can reveal relationships between manufacturing conditions and product quality.
This makes data architecture increasingly important.
Metrology systems need to connect measurement results with information from MES, ERP, PLM, machine tools, sensors and production systems. Data must also retain its context, including part identification, measurement uncertainty, environmental conditions, equipment status and traceability.
Without reliable and well-structured data, sophisticated AI models can produce unreliable conclusions.
The traditional metrology principles of accuracy, traceability and uncertainty therefore remain essential. AI does not replace these foundations; it builds upon them.
Changing Role of the Metrology Engineer
AI-native metrology will also change the role of the people who operate and manage measurement systems.
The metrology professional of the future is likely to spend less time creating repetitive inspection routines and more time managing measurement strategies, validating AI models, interpreting complex data and ensuring that automated decisions remain technically and statistically sound.
This introduces an important distinction between automation and autonomy.
Automation performs a task without human intervention.
Autonomy involves a system assessing a situation, making a decision and taking appropriate action within defined boundaries.
For metrology, the progression could therefore be:
Manual Measurement → Automated Inspection → AI-Assisted Inspection → AI-Native Metrology → Autonomous Quality Control
The industry is currently somewhere between the third and fourth stages. AI-assisted inspection is already delivering tangible benefits, while genuinely AI-native measurement architectures are still emerging.
Trust Will Be Critical
As AI becomes more deeply integrated into metrology, manufacturers will need confidence that automated decisions are reliable.
This presents a particular challenge because metrology has traditionally operated within a highly controlled environment of standards, calibration, uncertainty budgets and traceability. AI systems introduce a different model based on statistical inference and learned behaviour.
The industry will therefore need new approaches to validating AI-enabled measurement systems.
Questions will include: How was an AI model trained? How is its performance verified? How does the system respond to previously unseen conditions? Can its decisions be explained? How is model drift detected? And how can results remain traceable over the lifetime of the manufacturing process?
These questions will become increasingly important as AI moves from supporting inspection decisions to making them.
Towards Autonomous Quality
The ultimate vision is not an inspection system that simply detects more defects. It is a manufacturing environment in which measurement continuously informs and improves production.
In such an environment, inspection systems could learn from previous production, identify emerging process trends, adapt measurement strategies, predict quality problems and communicate directly with manufacturing equipment.
This would transform metrology from a predominantly verification function into an active intelligence layer within the factory.
The significance of this development extends beyond AI itself. It represents another step in the broader evolution of manufacturing: from measurement to data, data to intelligence, intelligence to prediction, and prediction to autonomous action.
AI-assisted inspection is already delivering practical benefits. The next challenge is determining how far industry can take the concept of AI-native metrology — where intelligence is not added to measurement as an afterthought, but becomes fundamental to how measurement systems operate. As manufacturing moves toward increasingly autonomous production, the ability to measure accurately will remain essential. But the ability to understand what the measurements mean, and act upon them, may become even more important.
