Precision Wafer Measurement Gains Importance as Advanced Packaging Evolves
The increasing adoption of advanced semiconductor packaging is placing greater emphasis on wafer geometry and thickness measurement, as manufacturers seek tighter process control across increasingly complex production flows.
The growth of GPU and AI processors, high-bandwidth memory (HBM), traditional CPUs, programmable logic devices and power semiconductors is driving the development of packaging architectures that combine logic, memory, interposers and specialized dies within tightly controlled structures. These processes place demanding requirements on wafer geometry, particularly where wafers undergo backside grinding, polishing and other thinning operations.
As wafer thickness decreases, the potential impact of relatively small variations becomes increasingly significant. Thinner wafers are more susceptible to breakage and deformation, while non-uniform material removal can introduce variations in thickness, bow, warp and flatness. Such conditions can subsequently affect wafer handling, bonding, stacking and final assembly.
For manufacturers, this makes measurement between process steps increasingly important. Detecting a thickness or geometry variation before a wafer progresses into a higher-value packaging operation provides an opportunity to adjust the upstream process and avoid propagating the problem downstream.
“Advanced packaging has made wafer thickness and geometry critical process variables,” said Todd Stukenberg, President of Vitrek. “Manufacturers need reliable data between process steps so they can detect variation before wafers reach costly packaging operations.”
Non-Contact Wafer Measurement
Vitrek’s MTI Instruments Proforma 300i and Proforma 300iSA systems are designed to provide non-contact wafer measurement using capacitance-based measurement technology.
The manual Proforma 300i is intended for point-based measurements of wafer thickness and total thickness variation (TTV). The semi-automated Proforma 300iSA extends this capability with programmable scanning and mapping, enabling measurement of thickness, TTV, bow, warp and flatness across the wafer.
Published specifications include thickness accuracy of ±0.25 µm and resolution of 0.05 µm. Depending on configuration and measurement routine, the Proforma 300iSA can collect up to 1,000 measurement points per minute.
The ability to map wafer geometry provides more than a single thickness value. Measurements taken at multiple locations can reveal non-uniform material removal and changes in wafer shape that may otherwise remain undetected by localized measurements.
Measurement Between Thinning Processes
Wafer measurement can be incorporated between grinding and polishing operations to monitor how material removal is progressing and identify process drift.
For example, mapping wafer thickness after grinding can reveal non-uniform removal across the wafer before subsequent processing takes place. Changes in bow, warp or flatness can similarly provide an indication that process conditions are affecting wafer geometry.
This type of in-process or between-process measurement is particularly relevant as wafer thinning becomes increasingly integrated with advanced packaging workflows. By identifying variation earlier, manufacturers can make process adjustments before wafers reach bonding, stacking or package assembly.
The requirement for such measurement is also being reinforced by the increasing complexity of semiconductor architectures. AI and high-performance computing applications are driving wider adoption of HBM and 2.5D and 3D integration, where multiple components must be assembled with tightly controlled physical relationships.
In this environment, wafer thickness measurement is not simply a final inspection activity. It can provide process data that supports control of material-removal processes and helps manufacturers protect the value added to wafers before they enter subsequent packaging operations.
For more information: www.vitrek.com
