Instruct3D Positions AdditiveOS at the Heart of Additive Build Intelligence
Following on from the recent ICAM 2026 event in Orlando, Instruct3D is reinforcing the role of AdditiveOS as the self-learning workflow at the heart of its Additive Build Intelligence proposition. Conversations at ICAM confirmed a clear and growing market need, metal AM users are not simply looking for more in-situ monitoring data. They are looking for better ways to predict build behaviour, understand what happened during the process, generate usable evidence, and improve the next build.
Turning Process Data Into Build Confidence
That is the purpose of AdditiveOS. Developed to work alongside Instruct3D’s VertX in-process monitoring hardware, AdditiveOS connects prediction, measurement, analysis, and learning into one continuous workflow. While many technologies in the AM quality space focus on observing the build, Instruct3D is positioning AdditiveOS as the intelligence layer that helps manufacturers turn process data into build confidence.
“ICAM reinforced what we are hearing across the market,” says Ben Thomas, CEO & Co-Founder of Instruct3D. “Manufacturers do not need a dashboard full of unexplained anomalies. They need connected intelligence that helps them make better decisions before, during, and after the build. AdditiveOS is central to that because it allows every build to become part of a learning workflow, not just another isolated dataset.”
Additive Build Intelligence – Predict | Build |Prove |Learn
Instruct3D’s approach is deliberately distinct from conventional in-situ monitoring. Cameras and sensors are used to capture meaningful process evidence, but they are not the end point. The value comes from linking that evidence to physics-based prediction, defect understanding, build reporting, verification, and future optimisation.
This reflects the company’s wider category position of Additive Build Intelligence. The aim is to help high-value metal AM users to ‘Predict. Build. Prove. Learn’.
Rob Snell, Co-Founder & CIO of Instruct3D, says, “The real challenge in metal AM is not simply seeing the process. It is understanding what the process data means and using that understanding to improve future builds. AdditiveOS is designed to make that connection. It helps move AM quality away from passive observation and toward a more intelligent, self-improving workflow.”
For manufacturers working in aerospace, defence, energy, medical, and advanced engineering, the implications are significant. AdditiveOS is designed to support reduced trial-and-error, faster process development, clearer build evidence, and greater confidence in the transition from successful printing to trusted production.
Thomas concludes, “The next phase of metal AM quality will not be defined by who captures the most data. It will be defined by who turns that data into better and more trustworthy builds. That is exactly where Instruct3D is focused.”
For more information: www.instruct3d.io
