SinceVision Launches Wide-Spot Laser Displacement Sensor for Precision Measurement
SinceVision has introduced the SGI-N030W, a new wide-spot laser displacement sensor designed to deliver high-speed, non-contact dimensional measurement on rough, textured and irregular surfaces. Using an expanded laser spot and optical triangulation, the sensor is designed to overcome measurement instability associated with conventional point-spot laser systems, particularly when inspecting materials with varying surface finishes.
The SGI-N030W extends SinceVision’s SGI Series laser displacement sensor portfolio, targeting applications in lithium-ion battery manufacturing, semiconductor processing and precision mechanical engineering where reliable micrometre-level measurement is required.
Conventional point-spot laser displacement sensors concentrate reflected laser energy onto a small area, making measurements susceptible to microscopic surface features such as scratches, grain boundaries, brushed textures and matte finishes. These characteristics can introduce unwanted signal variations that are interpreted as dimensional changes, potentially generating false defect warnings and requiring additional inspection.
The SGI-N030W addresses this limitation through a wide-spot optical configuration. By collecting reflected light across a broader surface area, the sensor effectively averages localised microscopic peaks and valleys before signal conversion. This reduces the influence of surface roughness and optical scattering, providing more stable displacement measurements on materials including drawn metals, sandblasted surfaces and coated battery foils.
Micrometre-Level Measurement Performance
The sensor operates with a reference distance of 30 mm and a measurement range of ±5 mm. SinceVision specifies repeatability of 0.05 µm when measuring a diffuse white target under static conditions, with linearity of ±0.02% of full scale across the measurement range.
A sampling frequency of 50 kHz, equivalent to a 20 µs update interval, supports high-speed measurement and monitoring of dynamic processes. Communication options include RS485, 100Base-TX Ethernet and switchable analogue outputs supporting either 4–20 mA current or 0–10 V voltage signals.
The system also incorporates master-slave synchronisation, allowing two sensors to operate in opposition for simultaneous measurement from either side of a component or moving material.
In-Line Thickness Measurement for Battery Production
One of the principal applications identified by SinceVision is in-line thickness measurement of lithium-ion battery electrodes. Coating thickness and uniformity are critical manufacturing parameters, influencing energy density, internal resistance and the long-term stability of battery cells.
Conventional offline inspection using contact micrometers or drop indicators can introduce operator variability and potentially deform wet or uncured electrode materials. Furthermore, periodic spot measurements cannot provide the continuous coverage needed to identify localised coating variations across an entire production reel.
The proposed SGI-N030W inspection arrangement uses two synchronised sensors positioned above and below a moving electrode web. Mounted on a calibrated, low-thermal-expansion marble gantry, the opposing sensor heads measure the respective clearances to the material. A system controller combines these measurements with the fixed mounting datum to calculate the electrode’s absolute thickness in real time.
According to SinceVision, production trials demonstrated stable, repeatable thickness measurement within ±0.3 µm at a web speed of 300 mm/s. The 50 kHz sampling frequency provides high longitudinal measurement resolution, enabling the detection of localised coating agglomerations, edge thinning and exposed substrate areas before the electrode material proceeds to cell winding.
Applications Beyond Battery Manufacturing
The SGI-N030W is also intended for semiconductor manufacturing, where non-contact measurement is important when handling sensitive wafer surfaces. Potential applications include wafer position verification, edge detection, height measurement and checking wafer seating and chuck alignment in atmospheric transfer modules and vacuum load-lock systems.
In precision assembly, the sensor can monitor the dynamic movement of voice coil motors, linear actuators and micro-steppers. Its 50 kHz sampling rate enables the capture of transient displacement, mechanical oscillations, settling behaviour and end-stop overshoot across the full measurement range.
Position data can be transmitted to machine control systems through its Ethernet interface, supporting real-time monitoring and process control.
Addressing Surface-Related Measurement Errors
Jack Li, Global Sales and Marketing Director at SinceVision, says that false defect warnings caused by surface texture remain a recurring challenge in battery manufacturing and precision assembly.
He explains that conventional point-beam laser sensors can interpret microscopic scratches and rough coatings as actual thickness variations, slowing production lines and creating a need for additional manual inspection. The SGI-N030W’s expanded optical spot is designed to average out these surface-related variations, while synchronisation between opposing sensor heads supports high-speed thickness verification.
For more information: www.sincevision.com
