IDS Combines NVIDIA Jetson Platform with Synchronized Multi-Camera Vision
IDS Imaging Development Systems has announced the introduction of the IDS GMSL2 Discovery Kit, an evaluation platform for modern embedded vision applications. The system combines intelligent camera modules with integrated image processing, GMSL2 (Gigabit Multimedia Serial Link) transmission technology, and an industrial-grade embedded PC based on the NVIDIA Jetson Orin NX platform.The embedded PC features matching GMSL connectors for the direct connection of the camera modules. Companies can borrow the Discovery Kit for evaluation and use it for their own development projects.
Applications where multiple cameras must transmit their image data synchronously and with low latency to an embedded PC place special demands on data transmission, synchronization, and integration. At the same time, cabling and integration effort should be kept as low as possible. For these requirements, IDS provides a preconfigured platform with which developers can evaluate corresponding system architectures.
The core of the Discovery Kit is intelligent camera modules with an integrated ISP (Image Signal Processor) and SoC (System on Chip). They capture image data via an onsemi AR0233 image sensor in Full HD resolution at 30 frames per second and support functions such as High Dynamic Range (HDR) and LED Flicker Mitigation. Depending on the version, several camera modules can be integrated into one system. The camera data is provided by the IDS driver software via the standardized V4L2 (Video for Linux 2) interface. This allows developers to work immediately with their own Python and OpenCV applications and evaluate the cameras without additional integration effort. Live images can be output directly or integrated into existing systems as streams via the Real-Time Streaming Protocol (RTSP). The connection between camera modules and the embedded PC is established via GMSL. The technology, originally developed for applications in the automotive environment, transmits image data, control information, synchronization signals, and power supply via a single cable. Multiple cameras can thus be operated synchronously and positioned flexibly. At the same time, greater distances between camera modules and the embedded PC can be bridged.
The system is particularly suitable for projects with distributed cameras in mobile applications that must use robust, long, and space-saving cabling. These include, among others, robotics systems, autonomous vehicles, smart farming, mobile machines, drones, aerospace systems, as well as systems in medical technology.
“With the Discovery Kit, developers and original equipment manufacturers can evaluate modern embedded vision architectures in their own applications. The foundations for customer-specific systems and subsequent series solutions emerge from such innovation projects. Our goal is to shorten the path from the initial idea to application-specific implementation,” says Kai Hartmann, Product Innovation Manager at IDS.
For more information: www.ids-imaging.us
