Dusty Robotics Elevates Construction Accuracy with Hexagon’s Leica AT500 Laser Tracker
Dusty Robotics, the construction robotics company that bridges the gap between design and field execution, has announced that it will use the Leica Absolute Tracker AT500 portable laser tracker from Hexagon’s Manufacturing Intelligence division. When paired with the Dusty FieldPrinter 2, the AT500 delivers significant improvements in setup speed and ease of use while maintaining Dusty’s industrial-grade 1/16″ (1.5875 mm) accuracy standard that is essential for mission-critical environments like data centers, healthcare facilities, and advanced manufacturing.
For projects where precision is non-negotiable, the Hexagon-powered solution reinforces Dusty’s position as the only viable option for automated layout, now with added operational efficiencies that further distance it from conventional total station accuracy.
This enhancement strengthens Dusty’s mission to transform construction execution into a seamless file-to-field process. By connecting design teams with field crews, Dusty enables better collaboration and communication, ensuring that digital intent is faithfully executed in physical reality.”
The AT500 reduces the friction between digital models and field execution,” said Tessa Lau, CEO and cofounder of Dusty Robotics. “We’ve seen teams significantly reduce setup and repositioning time with this integration. This means less time managing equipment and more time focused on the actual construction work that delivers value to projects.”
Designed for challenging environments, the Leica AT500 offers a compact form factor and robust durability in a more user-friendly package. Now equipped with the innovative lightweight LMF-embedded (LMF-e) interface, the Leica AT500 offers seamless connectivity to embedded Linux operating systems. This breakthrough enables dynamic trajectory correction for the Dusty FieldPrinter 2 without relying on high-end industrial Ethernet real-time feature pack, streamlining operations and reducing complexity. For contractors, the combination provides the speed and reliability needed for today’s fast-paced construction schedules.
The Leica AT500 is the longest-range Absolute Tracker offering an industry-leading measurement volume of up to 320 meters in diameter. Engineered for demanding environments, it boasts an IP54 certification for protection against dust and water exposure, and features a controllerless design to streamline setup. The built-in hot-swappable batteries ensure uninterrupted operation, while the PowerLock system enables the Tracker to automatically lock on and track the robot even if the measurement process is blocked or interrupted. Simply put,the Leica AT500 is the ideal solution for construction jobsite work, surpassing any previous laser tracker in performance and usability.
“The integration of the AT500 with Dusty’s FieldPrinter 2 gives construction teams a practical solution for accelerating jobsite setup and improving workflow efficiency,” said Chris Jundt, Product Sales Manager – Trackers, North America, Hexagon. “This combination addresses real challenges faced by field professionals who need to quickly translate digital designs into physical execution.”
The AT500 integration also enhances Dusty’s floor elevation capabilities, enabling teams to measure flatness and floor deviations with the efficiency required for mission-critical applications in healthcare and industrial settings. This expanded functionality demonstrates how Dusty continues to evolve beyond layout into a comprehensive design-field collaboration platform.
Dusty Robotics will now offer the AT500 alongside its existing tracker options for FieldPrinter 2 deployments, reinforcing its commitment to connecting design teams with field execution through tools that are fast, reliable, and user-friendly.
