Why Tolerances Can Make or Break Production Cost
Tolerances are one of the most powerful and misunderstood parts of product design. A tolerance tells the manufacturer how much variation is acceptable. That simple instruction affects machining time, inspection effort, scrap risk, supplier choice, assembly quality, and production cost.
The problem is not tight tolerances. The problem is using tight tolerances without a clear functional reason.
Every Dimension Does Not Deserve The Same Control
A common mistake is treating all dimensions as equally important. In reality, some features control alignment, sealing, motion, safety, fit, or performance. Others may only affect appearance or clearance. When every dimension is tightly controlled, the supplier must treat the entire part as critical.
That increases cost and may still fail to protect the features that matter most.
Tight Tolerances Create Hidden Costs
A tighter tolerance can require slower manufacturing, better tooling, controlled temperature, extra inspection, specialized equipment, or more experienced suppliers. It can also increase scrap because parts that function well may be rejected for dimensions that did not need to be so strict.
The cost is not always visible in the design stage, but it appears in quotes, lead time, inspection reports, and production yield.
Loose Tolerances Can Also Be Expensive
The solution is not to make every tolerance loose. Loose or unclear tolerances can cause assembly problems, rattling, leaks, misalignment, premature wear, cosmetic issues, or field failures. If an interface is critical, it should be controlled.
Tolerance strategy is about placing precision where it protects function.
Tolerance Stack-up Affects Assemblies
Individual parts may be within tolerance but still fail as an assembly if variation accumulates in the wrong direction. This is tolerance stack-up. It matters in mechanisms, enclosures, fastener patterns, sealing surfaces, sliding parts, and multi-component products.
Designers should evaluate how parts interact, not only whether each part can be manufactured alone.
Inspection Should Be Planned Early
A tolerance is only useful if it can be measured. Some features are difficult to inspect because of geometry, access, datum ambiguity, or lack of clear drawing information. If inspection is unclear, suppliers may interpret requirements differently.
Drawings should communicate not only the desired dimension but also the functional relationship between features when needed.
GD&T Can Help When Used Correctly
Geometric dimensioning and tolerancing can clarify how features relate to datums, orientation, position, flatness, perpendicularity, and other controls. Used properly, GD&T can protect function while avoiding unnecessary restrictions.
Used poorly, it can confuse suppliers and increase cost. GD&T should be applied with manufacturing and inspection in mind.
Prototype Tolerances May Not Scale
A prototype shop may hold certain dimensions for a few parts, but that does not mean the same approach is appropriate for production quantities. Production introduces variation over time, tooling wear, material lot changes, operator differences, and inspection sampling.
Teams should review tolerances before moving from prototype to production.
How To Improve Tolerance Decisions
A practical tolerance review should ask:
- Which dimensions affect function?
- Which features control assembly?
- Which surfaces need inspection?
- Which tolerances are tighter than necessary?
- Which tolerances are missing?
- What process will produce the part?
- Can the supplier measure what is specified?
Precision Should Be Intentional
Tolerances are not just numbers on a drawing. They are instructions that shape manufacturing cost and quality. Good tolerance strategy helps teams avoid overpaying for unnecessary precision while still protecting the performance of the product.
The best designs make precision intentional, measurable, and connected to function.
Author: Aleksandar Tomic is the founder of X-PRO, an engineering and product development firm supporting CAD, mechanical design, drawings, tolerance review, prototyping, and manufacturability planning.
