SensoPart Launches Next-Gen 3D Object Sensor
The new DTECT Object 3D is designed for a wide range of users in automation technology. Using patented stereo technology with structured light, the device accurately measures volume information regardless of reflectivity and reliably detects even dark or hard-to-see objects.
Intelligent Position Control and Completeness Checks
Whether on vibratory conveyors or in assembly, DTECT Object 3D makes it faster and easier than ever to reliably detect the position or completeness of objects. For example, the system can accurately determine whether an object is lying prone or supine on vibrating conveyors. The desired ‘good’ or ‘bad’ condition can be set at the touch of a button, often eliminating the need for complex separation mechanisms – saving both time and costs.
The solution also excels at checking the completeness of containers or assemblies: deviations are reliably detected without complex parameterization. This makes the system ideal for flexible production processes where efficiency and precision are essential.
Two Versions for Maximum Application Flexibility
Close-Range Version (up to 200 mm): Ideal for completeness or presence checks on objects in plastics and assembly technology or on vibratory conveyors
Long-Range Version (up to 500 mm): Optimal for completeness checks packaging technology or for presence checks on conveyor belts
The intuitive operation of DTECT Object 3D is supported by a color display on the device. The buttons allow quick adjustments of the field of view or relevant height to match the application—no external software required. After teach-in, the operating status or sensor result (good/bad) is displayed via the illuminated frame surrounding the device. Additional settings can also be easily configured using SensoTune software.
Sensor features include:
- Up to 100 fps for high-speed processes
- M12, 5-pin connection for easy integration as with standard sensors
- Compact F55 housing – robust and proven
- Multiple patented depth imaging technology
- Intuitive color display with depth image visualization
With this solution SensoPart reinforces its commitment to making complex sensor technology as easy as possible for users to use – object detection reimagined.
For more information: www.sensopart.com
