New OptimScan Q12 Delivers Fast, Flexible, and Accurate 3D Inspection
SHINING 3D has introduced the OptimScan Q12, a new high-precision 3D scanner designed to meet increasing demands for fast, accurate, and automated inspection across manufacturing and quality control applications. Compact and versatile, the system combines high-resolution imaging, flexible scanning ranges, and seamless automation capabilities.
The OptimScan Q12 is equipped with four 12.3-megapixel cameras, enabling the capture of fine surface details with an accuracy of up to 0.005 mm. The scanner supports two scanning ranges—160 × 110 mm for detailed features and 430 × 300 mm for larger parts. Transitions between scan ranges are automatic, with no manual adjustments required, and data is merged through integrated software for a unified output.
Monocular-Stereo Fusion Technology
To improve performance on complex geometries, the system features Monocular-Stereo Fusion (MSF) technology, which enhances scan coverage on intricate edges and corners. A dual-chip computing module enables rapid data processing, capturing up to 12 million points in under a second. The scanner also includes multiple exposure modes, allowing it to adapt to challenging surface materials, such as reflective or dark finishes.
Designed for integration into a variety of workflows, the OptimScan Q12 supports handheld scanning, semi-automated setups using turntables, and full robotic automation. It is compatible with existing 3D inspection platforms, facilitating end-to-end workflows from data acquisition to quality reporting.
With its combination of precision, speed, and deployment flexibility, the OptimScan Q12 is positioned as a practical solution for manufacturers seeking to implement real-time, repeatable 3D inspection in production environments.
With the release of OptimScan Q12, SHINING 3D has also introduced its new high-end measurement brand—SHINING 3D Metrology. Over the past 20 years, SHINING 3D has poured its heart into perfecting 3D vision technology. Today, SHINING 3D Metrology distills that passion and expertise into a brand devoted to advancing high-end precise measurements. The brand specializes in delivering end-to-end 3D metrology solutions and meets the stringent demands for efficiency, precision, and reliability in industrial manufacturing.
