Pika Portable 3D Scanner Brings Scanning Into a Pocket Era
Creality has introduced Pika, a new AI-powered portable 3D scanner developed in collaboration with Orbbec. The device combines high-precision scanning, AI-enhanced processing, and a compact, mobile design, reflecting the growing convergence of intelligent software and advanced 3D imaging hardware.
The launch coincided with Creality’s debut on the Hong Kong Stock Exchange and the announcement of an expanded strategic partnership between Creality and Orbbec. As part of the agreement, the companies will establish a ‘3D Scanner Digital Joint Innovation Center’ and jointly develop a next-generation AI vision platform for 3D printing applications.
According to the companies, the partnership is intended to accelerate innovation across the digital manufacturing ecosystem by combining Creality’s expertise in consumer and professional 3D printing with Orbbec’s capabilities in 3D vision and AI technologies.
Compact Design Targets Mobile Scanning Applications
A key feature of the Pika scanner is its portability. Measuring 100 × 60 × 35 mm and weighing 260 g, the device is designed for handheld operation and can be used directly with a smartphone, eliminating the need for a PC during data capture.
The scanner includes an integrated HD display for real-time scan monitoring and a quick-release, replaceable battery intended to support extended field operation. By simplifying setup and workflow requirements, Pika aims to make professional-quality 3D scanning more accessible to designers, engineers, creators, and hobbyists.
High-Speed Data Capture
Pika is built around a global shutter 3D camera architecture, which helps eliminate motion blur and tracking instability commonly associated with rolling-shutter systems during handheld scanning.
The scanner supports line-laser scanning at up to 40 frames per second when connected to a smartphone and infrared scanning at up to 20 FPS. When connected to a PC, line-laser scanning performance increases to a maximum of 110 FPS.
The combination of high frame rates and global shutter imaging is designed to improve scanning speed and data stability across a range of applications, including object digitization, full-body scanning, and the capture of complex geometries.
Dual Scanning Technologies in a Single Platform
Pika integrates both 7-line blue laser and infrared structured light technologies, enabling users to switch between high-accuracy and high-speed scanning modes.
The blue laser system delivers accuracy of up to 0.03 mm, making it suitable for applications requiring detailed surface capture, such as reverse engineering, inspection, cultural heritage preservation, and the digitization of collectibles or small mechanical components.
Infrared structured light mode is optimized for larger objects, human-body scanning, and marker-free workflows, providing greater flexibility across a broader range of scanning scenarios.
The scanner also incorporates AI-driven algorithms for object tracking, data processing, and workflow automation. An AI-powered body completion function automatically generates complete 3D body models, reducing the amount of manual editing typically required for portrait and figure-based 3D printing applications.
Expanding Access to AI-Driven 3D Imaging
Since establishing their partnership in 2023, Orbbec and Creality have collaborated on several 3D scanning and smart manufacturing solutions built on Orbbec’s underlying 3D vision technologies.
The introduction of Pika highlights the companies’ shared focus on making advanced 3D imaging and digital creation tools more accessible to a wider audience. As AI capabilities become increasingly integrated into scanning workflows, portable devices such as Pika are expected to play an important role in expanding the adoption of 3D capture technologies across both professional and consumer markets.
For more information: www.creality.com
