Four-Camera OptimScan Q12 HD Advances High-Resolution Optical Metrology
SHINING 3D has announced the launch of the OptimScan Q12 HD, a new high-precision 3D inspection scanner designed for industrial metrology applications that require exceptional accuracy, detailed data acquisition, and flexible automation capabilities.
With an accuracy of up to 0.004 mm and a minimum point distance of 0.02 mm, the OptimScan Q12 HD pushes beyond the conventional performance limits of fringe projection optical scanning systems. Equipped with four high-resolution cameras, the system captures complex surfaces and minute features with exceptional clarity and precision.
Supporting Precision Inspection Across Multiple Industries
Civil Aviation: For the inspection of critical components such as engine blades and turbine blades, the OptimScan Q12 HD delivers highly accurate capture of fine blade edges, curved surfaces, and intricate structural features.
Its high-resolution scanning capability supports dimensional inspection, wear analysis, reverse engineering, and quality verification of complex aerospace components, helping manufacturers and maintenance teams improve inspection reliability and efficiency.
3C Electronics and Precision Injection Molding:
In industries such as 3C electronics and precision injection molding, manufacturers face increasing demands for dimensional consistency, fine-detail verification, and high-efficiency quality control.
Components including earbud housings, precision plastic parts, connectors, electronic casings, and molded structural components often feature miniature geometries, glossy surfaces, thin walls, and complex edge transitions that are challenging for conventional measurement methods. The OptimScan Q12 HD enables high-resolution 3D digitization of small and intricate components, helping manufacturers accurately inspect fine features, assembly gaps, deformation, shrinkage, and surface defects.
For batch inspection scenarios, the system can also integrate with robotic automation solutions, enabling repeatable and efficient inspection workflows suitable for high-volume manufacturing environments.
Medical Devices and Cultural Heritage Digitization
Medical devices and cultural heritage artifacts both require highly accurate, non-contact 3D digitization methods capable of preserving intricate geometries and subtle surface characteristics.
In the medical field, precision instruments and small components often contain fine contours, narrow structures, and freeform surfaces. The OptimScan Q12 HD captures these detailed geometries for applications including dimensional inspection, product development, and digital archiving.
For cultural heritage preservation, the system is well suited for digitizing artifacts featuring delicate engravings, relief patterns, and complex carved structures. Its high-detail scanning capability enables highly faithful digital reproduction while minimizing physical contact with valuable objects.
Advancing the Future of High-Precision 3D Inspection
Industries are rapidly moving toward higher standards of inspection accuracy, automation, and digitalization. With the launch of the OptimScan Q12 HD, SHINING 3D continues to expand the boundaries of high-precision optical metrology, delivering a 3D inspection solution that combines micron-level accuracy, efficient workflows, and flexible automation for advanced industrial applications.
