AI Inspection Needs a Version Passport for Every Measurement
A digital inspection result may include an accurate measurement and still be wrong for the job. Suppose a part is checked against an obsolete drawing revision. The instrument records the dimension faithfully, the software produces a polished report, and everyone receives the wrong conclusion with impressive speed.
Connected metrology makes that failure mode more important. The October 26 Metrology News account of persistent identification describes how Quality Information Framework data can preserve the identity of a measured characteristic across product definitions, inspection plans, and results. The technical promise is traceability. The management challenge is ensuring that each decision follows the correct version of the requirement.
Manufacturers adopting AI-assisted inspection should give every consequential measurement a version passport. The passport does not need to be a new software product. It can begin as a set of fields that travel with a measurement: approved drawing or model revision, characteristic identifier, inspection-plan revision, instrument or method, result timestamp, and identity of the person or system that approved the disposition.
Why this additional attention? AI can summarize an inspection report, point to an apparent deviation, or recommend which cases need review. But a tool that receives results without version context may compare an observation with the wrong specification. The arithmetic can be correct while the conclusion is invalid.
The National Institute of Standards and Technology’s 2026 smart-manufacturing roadmap highlights integration of heterogeneous data and trustworthy operation as continuing challenges for industrial AI. A version passport targets a specific part of that problem: it makes the origin and applicable conditions of a measurement visible to the next decision-maker.
Quality teams can test the idea before integrating a new platform. Select a small set of completed inspection records. Include one legitimate out-of-tolerance result, one conforming part, and one example with mismatched revisions. Ask an AI assistant to summarize the evidence. Require it to identify the applicable revision and flag missing provenance. Compare its responses with an experienced quality engineer’s determination.
Do not simply ask how often the assistant labels a part good or bad. Record whether it catches a revision mismatch, whether it invents an unstated tolerance, and whether it can point to the approved source behind a conclusion. Those are the errors that digital handoffs often conceal.
Assign clear ownership when records disagree. A quality engineer may determine whether a measurement is valid, while design engineering confirms the governing definition and manufacturing determines whether production can continue. The escalation route must be settled before the alert appears, rather than negotiated during a shipment dispute.
This argument differs from the familiar demand for more AI-versus-human comparisons. Even perfect agreement between human and automated inspectors can reinforce the wrong decision if both were given an obsolete specification. The reference itself needs scrutiny.
Automation can make measurement data travel farther and faster. A reliable chain of custody ensures that the drawing, feature, method, and result still belong together when the decision is made. The next generation of connected inspection should make that connection impossible to ignore.
Author: Gleb Tsipursky, PhD, a behavioral scientist, CEO of Disaster Avoidance Experts, and author of The Psychology of AI Adoption at Work: From Resistance to Results (Georgetown University Press, 2026) https://disasteravoidanceexperts.com/aibook
