What Auditors Find in Calibration and Measurement Records
Plants rarely get calibration findings because a gauge was wrong. They get them because nobody can show, on the day, that the gauge was right, that it was the right gauge for the job, or what happened to the parts it measured once it turned out to be wrong.
A calibration lab can do flawless work and the plant can still get a nonconformity, because the evidence chain between the reference standard and the accept or reject decision on the floor has a gap. This article looks at that chain from the auditor’s side: what ISO 9001 and API Spec Q1 require, where the gaps usually appear, and how to keep records current between audits. The examples are composites drawn from several audits; none describes a single company.
What Standards Actually Ask For
ISO 9001:2015 clause 7.1.5.1 requires resources that ensure valid and reliable results when measurement is used to verify conformity. They must be suitable for the specific measurement and maintained for continuing fitness for purpose, with documented information retained as evidence.
Where traceability is required, clause 7.1.5.2 requires equipment to be calibrated or verified at specified intervals or prior to use against standards traceable to international or national standards, identified so its status can be determined, and safeguarded from adjustment, damage or deterioration. When equipment is found unfit for its intended purpose, the organization must determine whether the validity of previous measurement results has been adversely affected and take appropriate action.
ISO 9001:2026 was published on 16 September 2026, with a three-year transition, so most audits are still run against the 2015 edition. Published briefing material on the new edition describes the clause 7.1.5 changes as wording only, such as the retitled 7.1.5.2, “Traceability of measurement results.”
API Spec Q1, 10th edition, is more specific. Clause 5.8.2 requires a documented procedure for testing, measuring, monitoring and detection equipment (TMMDE) covering unique identification, calibration status, traceability, method and acceptance criteria, frequency and when the interval begins, as-found and as-left measurements, controls against unintended use of out-of-calibration equipment, and third-party, proprietary, employee-owned and customer-owned equipment. When equipment is found out of calibration, it requires an assessment of the validity of previous measurements, actions on equipment and product, and evidence of customer notification if suspect product has shipped. Clause 5.8.3 requires status to be identifiable by the user before and during use, and clause 5.8.5 requires a registry with a unique ID for each item.
Together, they ask a plant to prove four things: the instrument is suitable, its accuracy is traceable, the user can tell whether it is fit to use, and the organization knows what to do when it is not.
Finding 1: Traceability that stops at the certificate
A frequent traceability problem is not a missing certificate but one nobody has read: no reference standards stated, a provider whose accreditation scope does not cover the parameter or range, or results with no statement of whether the instrument met the plant’s own acceptance criteria. If the plant never defined what error is acceptable for that instrument and use, the certificate shows a measurement, not a decision.
In one composite case, a mid-sized machine shop had a current certificate on file for every gauge in the register. But the bore gauge certificates came from a lab whose accreditation scope did not cover that measurement range, which the shop’s aerospace customer required. Operators also checked micrometers in-house against a gauge block set, yet the check sheets never recorded which set was used, and that set had not been calibrated in over two years. The binder looked complete; the traceability chain did not hold up once it was followed.
Finding 2: Status nobody can read at the point of use
Status is easy to check, so many findings are written here. An auditor walks to a bench, picks up a caliper, and asks the operator whether it is in calibration.
In a composite drawn from typical floor walks, that caliper sat on an inspection bench in an oilfield equipment shop. Its label had worn off, the operator assumed quality tracked it, and its ID was missing from the register entirely. Back in the office, the register listed several gauges nobody could locate, and recall depended on one technician who had been on leave for a month.
Overdue calibration is the symptom. The cause is usually a recall system that depends on one person. API Q1 also requires the procedure to define when the interval begins, so a gauge stored for months after calibration may be in or out of interval depending on that rule.
Finding 3: The out-of-tolerance question nobody answered
This finding matters most to product quality, because both standards require the plant to assess what an out-of-tolerance instrument did to previous results. Without as-found data, there is no way to judge how far off the instrument was or for how long.
This composite reflects a pattern seen repeatedly. A thread ring gauge came back from the lab with an as-found reading outside tolerance. It was adjusted, recertified and returned to the cell, and the record ended there. Asked which lots had been accepted with that gauge since its last good calibration, nobody could say, and some of that product had already shipped. The plant had to trace the gauge’s use through travelers, assess the affected lots, document the disposition and notify the customer. That took far longer than a short out-of-tolerance form would have.
A defensible assessment answers a short list of questions. Which parts, lots or tests relied on this instrument since its last good calibration? How large was the as-found error compared with the tolerances checked? Could it have changed an accept or reject decision? What was done with the affected product, and who decided? If product shipped, was the customer told, and where is the record? Even when the answer is that no decision could have changed, a short written rationale closes the loop.
Finding 4: Instruments that live outside the system
API Q1 names employee-owned and customer-owned equipment directly, and both remain a steady source of findings.
As a composite of typical findings: on second shift, a senior machinist was accepting parts with his own micrometer, a good instrument he had owned for years, but it had never been entered in the register or calibrated by the plant. The same shop used a customer-supplied pressure test fixture that nobody had added to the system because “it belongs to the customer.” Neither tool was the problem. The problem was that acceptance decisions rested on equipment the quality system did not know existed.
The fix is a rule, not a ban: any instrument used to accept product is in the register, whoever owns it. Anything else is marked reference only.
Finding 5: Suitable on paper, not for the job
Both standards require suitability for the planned measurement, and API Q1 5.8.3 also requires suitable environmental conditions. A certificate does not demonstrate suitability; the plant needs its own documented basis for matching instruments to characteristics.
In a composite of situations seen during audits, a valve shop was hydrotesting at a few hundred psi with a calibrated gauge whose range was several times the test pressure, so the reading sat at the bottom of the dial where small differences were hard to resolve. Elsewhere on the floor, a caliper with fairly coarse resolution was accepting a feature with a very tight tolerance. Both instruments had valid certificates, but the plant had no documented basis for why either was suitable, and the certificate could not provide one.
Keeping Measurement Records Current Between Audits
Plants that handle these audits well treat measurement records as daily work:
One Register, Complete: Every instrument used to accept product has a unique ID, location, owner, interval, start rule and due date, reconciled periodically against what is on the floor.
Certificates Checked On Receipt: Compare results with predefined acceptance criteria, confirm reference standards and accreditation scope, check for as-found data, and sign the review.
Status Readable At The Point of Uuse: Labels that survive the environment, and a visible way to mark equipment out of service or reference only.
Recall That Does Not Depend on Memory: A scheduled review of due dates, with loaners and equipment out for calibration tracked.
An Out-of-Tolerance Form That Gets Used: It forces the Finding 3 questions to be answered, with product disposition and any customer notification attached.
Ownership and Suitability Rules: Personal, customer-owned and third-party equipment enters the system or is excluded from acceptance, and each instrument’s range and resolution are justified for its use.
Internal Audits That Pick Up Instruments: Sample real gauges on the floor, not only the files in the quality office.
When a Finding is Raised
A calibration finding is a nonconformity like any other, and ISO 9001 clause 10.2 expects corrective action that deals with the cause, not only the instance. Recalibrating the overdue gauge corrects that gauge. Asking why the recall system missed it, and whether other instruments were missed the same way, is what prevents the next finding. Auditors notice the difference.
Measurement is the evidence behind every conformity decision a plant makes. Keeping it complete, current and easy to show is less about passing an audit than about trusting the numbers on an ordinary Tuesday.
Authors: Konstantin Dolgan is CTO of QMS2GO, which develops quality management software for ISO 9001 and manufacturing compliance. Onega Ulanova is lead auditor on 200+ API Q1 and ISO 9001 audits.
For more information: www.qms2go.com
