Verisurf Device Interface Supports New API iLT Laser Tracker
Verisurf Software, a leader in measurement solutions and model-based inspection software, has announced enhanced workflow capabilities enabled by full application support for the API iLT laser tracker. Built on Verisurf’s universal, CAD/CAM-based metrology platform, manufacturers can unify inspection, alignment, assembly, and reverse engineering processes within a single, model-based environment, driving faster, more accurate, and more repeatable manufacturing outcomes.
Verisurf’s open architecture and hardware-agnostic design integrate seamlessly with virtually all coordinate measuring systems, including CNC CMMs, portable arms, scanners, and laser trackers. This universal compatibility allows manufacturers to standardize workflows across equipment and facilities, minimize training requirements, and scale metrology operations in line with modern digital manufacturing strategies.
Extending this platform, Verisurf now provides full support for the API iLT laser tracker, the world’s smallest and most portable laser tracker. As part of the Verisurf ecosystem, the iLT becomes a flexible, mobile measurement solution that leverages the same software, workflows, and data standards used across the manufacturing enterprise.
The combination introduces new levels of agility for manufacturers requiring precision measurement in dynamic environments. Whether deployed on the shop floor, in the field, or across distributed production facilities, the API iLT, powered by Verisurf, enables consistent, repeatable workflows supported by intelligent automation and comprehensive reporting tools.
“Modern manufacturing depends on connected, model-based workflows that turn measurement into actionable insight,” said Nick Merrell, Executive Vice President at Verisurf. “Verisurf delivers that foundation. By extending our platform to the API iLT tracker, we give customers the ability to apply the same proven workflows anywhere, without sacrificing accuracy, consistency, or control.”
Unlike traditional metrology solutions, Verisurf combines CAD, CAM, and inspection into a single platform, ensuring alignment between design intent and manufacturing execution. Users can automate processes, guide assemblies in real time, and validate parts without interrupting production, supporting true closed-loop manufacturing.
The API iLT enhances these capabilities with unmatched portability. Measuring just 14 inches tall, weighing under 20 pounds, and fully battery-operated, the system is designed for mobility without compromise. Its onboard camera enables rapid target acquisition and tracking, while its compact form factor allows the entire system to fit in a backpack for easy transport.
“The ease of use and universal compatibility of Verisurf software make it the perfect fit for the API iLT,” said API’s Matt Ledger. “Customers can deploy a highly portable tracker while maintaining the same trusted workflows and software environment used throughout their operations.”
Verisurf Software, Inc. is a measurement solutions company dedicated to delivering advanced surface analysis, quality inspection, automation, assembly guidance, and reverse engineering solutions. Built on a powerful CAD/CAM platform, Verisurf is a leader in Model-Based Definition (MBD), open standards, and interoperability with all major CMM hardware and CAD systems. Verisurf solutions enable manufacturers to produce higher-quality products in less time while improving process efficiency and control.
For more information, visit www.verisurf.com
