Reliable Force Measurement Starts with Accredited Calibration
Reliable measurement data remains fundamental to maintaining stable manufacturing processes and ensuring consistently high product quality across industrial applications. In particular, the calibration of force sensors plays a critical role in preserving measurement accuracy and process reliability.
Even high-quality force transducers can be affected over time by external influences such as temperature fluctuations, humidity, and general component aging, all of which can impact measurement performance. As a result, regular recalibration is essential, particularly for companies operating certified quality management systems in accordance with DIN EN ISO 9001 requirements.
ISO/IEC 17025 Calibration Ensures Global Traceability
Against this backdrop, calibration performed in compliance with the European standard ISO/IEC 17025:2017 has become increasingly important. The internationally recognized standard ensures that measurement results remain traceable, reproducible, and globally comparable — a key requirement for manufacturers operating within international supply chains and highly regulated industries.
As part of the INELTA Group, VYPRO operates its own accredited testing laboratory and provides manufacturer-independent calibration services for a wide range of force transducers in accordance with ISO/IEC 17025:2017.
The company says customers benefit from internationally recognized calibration results that support audit compliance and certification processes while improving confidence in measurement reliability.
Wide Range of Force Sensor Calibration Services
VYPRO’s calibration capabilities cover numerous sensor types, including tensile and compressive force sensors, ring force sensors, bending beam and shear beam load cells, tensile test slats, and custom-designed force sensors.
ISO and in-house calibrations are available for both tensile and compressive force applications up to 200 kN. The service portfolio also includes technical inspections and repair services where required.
For manufacturers operating under tight production schedules, expedited calibration services can also be arranged on request. Following calibration, customers receive an internationally recognized calibration certificate confirming compliance and measurement traceability.
Supporting Process Stability and Compliance
Accurate and repeatable calibration delivers several operational benefits for industrial manufacturers. Early detection of measurement deviations helps prevent process instability, supports long-term production consistency, and ensures compliance with regulatory and quality standards.
In globally connected production environments, calibration traceability also helps maintain comparability of measurement results across different facilities and international operations, supporting standardized quality assurance throughout the supply chain.
For further information: www.inelta.de
