Close The Loop Between Measurement and Machining
For decades, machining and inspection have lived in separate worlds: the CNC machine on one side, the CMM on the other, and data produced on both ends, but never truly connected. Manufacturers have filled that gap with manual calculations, trial runs, and educated guesses. The cost: wasted time, scrap, and a quality loop that never fully closes.
Now, Metrologic DCS ends that. The Manufacturing Quality Pack is the first software suite to genuinely bridge the manufacturing world and the inspection world, turning CMM measurement data into exact CNC corrections, without interpretation, without friction.
Anticipate. Correct. Understand. The loop is closed :
Deformation Simulator – Anticipate what can go wrong before a single part is machined.
It anticipates issues before the first part is cut. Engineers virtually simulate geometric deformation on the CAD model — validating their tolerance strategy before any chip falls.
Machining Corrector – Correct deviations the moment they are measured.
Not after a trial run, not after a debate. Turns measured deviations into exact CNC corrections — tool offsets, work references, axis corrections — automatically. No manual calculations. No guesswork. A Predictive Mode even forecasts how the next part will measure before it runs.
Decomposition Analyzer – Understand what actually caused the problem, not just that one existed.
Until now, each of these required a different tool, a different workflow, and a different person. Breaks down any deviation into its four fundamental contributors — form, size, orientation, and position — in one click, in 3D, directly on the part geometry. It gives quality engineers root causes, not just numbers.
All three capabilities run inside the same Metrolog Software environment, with no new hardware, no migration, and no disruption to existing inspection programs. They are compatible with CMMs from all major manufacturers.
‘We built the Manufacturing Quality Pack because the gap between the CMM and the CNC has cost manufacturers too much for too long. The loop is now closed ” staes Sylvain Anselmetti GD&T Expert at Metrologic Dcs.
The Manufacturing Quality Pack is built for manufacturers who can no longer afford the cost of trial runs, interpretation errors, and unexplained non-conformances.
For more information: www.metrologicdcs.com
