Robust Force Transducers Designed for High-Performance Industrial Measurement
Force measurement is fundamental to manufacturing, product validation and quality assurance, where even small deviations can influence performance, safety and compliance. Designed for demanding industrial and research applications, GTM’s K Series force transducers combine high precision with exceptional durability, making them suitable for both static and dynamic force measurement across a broad range of industries.
The K Series force transducers are engineered to deliver accurate tensile and compressive force measurements in industrial manufacturing, automated test systems and research laboratories. Their compact, rugged construction and excellent linearity enable reliable operation in environments where measurement accuracy and long-term stability are essential.
A key feature of the K Series is GTM’s proprietary jump ring measuring principle, an integrating measurement method that minimizes the influence of parasitic forces. By reducing sensitivity to lateral forces, bending moments, torsional loads and temperature variations, the sensors maintain high measurement accuracy even in challenging operating conditions.
Designed to withstand demanding industrial environments, the transducers can tolerate overloads of up to 300% of their nominal capacity without mechanical failure and up to 150% without permanent zero-point shift. This robust performance makes them well suited for material testing, component validation, production process monitoring and quality assurance, as well as integration into both static and dynamic testing systems.
Automotive and Mechanical Engineering Applications
The automotive and mechanical engineering sectors represent two of the primary application areas for the K Series. The sensors are widely used in chassis and steering system test benches, monitoring assembly forces during bearing and pin press operations, and validating clutches, transmissions and drivetrain components.
Available across a wide measurement range, from just a few newtons to several hundred kilonewtons, the sensors provide consistent accuracy throughout their operating range. Their resistance to environmental influences such as vibration, temperature fluctuations and humidity makes them particularly suitable for production and development environments where repeatable measurement performance is critical.
The K Series is also designed for compatibility with leading industrial measurement and data acquisition systems, simplifying integration into existing testing and automation platforms.
Supporting Tire Development and Production
Force measurement plays an equally important role in tire development and manufacturing. During product development, the sensors are used to measure vertical, braking and lateral forces on tire testing systems while also supporting the analysis of rubber compound behaviour. In production, they monitor joining forces during assembly operations and control critical processes such as vulcanization.
Under these dynamic operating conditions, the K Series maintains high measurement accuracy while benefiting from temperature compensation and long-term measurement stability. These characteristics make the sensors particularly well suited for endurance testing, fatigue analysis and long-duration validation programmes where reliable data is essential.
With their combination of precision, overload protection and resistance to environmental influences, GTM’s K Series force transducers provide manufacturers and test engineers with a versatile force measurement solution capable of meeting the demands of modern industrial testing, process control and quality assurance.
For more information: www.gtm-gmbh.com
