New Measurement Technology Allows High-Speed 3D Vehicle Interior Crash Recordings
The Fraunhofer Institute for Applied Optics and Precision Engineering IOF has been developing systems for the high-speed capture of 3D data for many years. With goCRASH3D, the team is now presenting a new system that records 3D data during crash tests inside the test vehicle. It shows the deformation and movement of vehicle components during a collision in a way that was previously not possible or only possible to a limited extent.
For more than ten years, Fraunhofer IOF in Jena, Germany, has been working on capturing 3D data with high-speed cameras. Essentially, such a system consists of two cameras, a projector and a computer. “The crux of the matter is not actually the camera, but the lighting,” explains project manager Kevin Srokos. The researchers in Jena further developed the GOBO technology from stage technology for their purposes years ago.
With the GOBO technology, a disk with an irregular fringe pattern rotates in front of a high-power light source. This produces a non-periodic sinusoidal pattern on the object to be measured. This allows points in the images from the cameras looking at the object from different angles to be matched. The 3D coordinates for the points in the images are calculated from the position of the cameras and the offset of the image points.
Automotive Sector Application
The IOF team tested their system in the automotive industry very early on. “Back then, the system was used to track the deployment of an airbag with time resolution,” reports Srokos. “But back in 2017, we also had the idea of moving the system into the interior of the vehicle.” In a joint project with a major German car manufacturer, the Jena team set up a demonstrator for this purpose, which has been used for tests by the project partner since 2023.
With goCRASH3D, it is possible to observe processes in the footwell, for example, that were previously inaccessible or only accessible to a very limited extent. Areas obscured by the deploying airbag can also be tracked in this way.
The goCRASH3D system is currently being used by the project partner and further developed at Fraunhofer IOF. At the institute in Jena, the high-speed recordings have already been coupled with other cameras so that the 3D images can be combined with additional spectral information.
The goCRASH3D system was developed for and with the automotive industry. “However, we can also imagine other applications in the safety sector or in sports medicine,” explains Kevin Srokos. In the medium term, the technology for 3D high-speed recordings is an excellent solution for the growing safety requirements in the automotive sector.
For more information: www.iof.fraunhofer.de
