High Texture Resolution Hand-Held 3D Color Scanner Launched
Shining 3D has announced the launch of EinScan H2 hand-held color 3D scanner. The H2 improves on its predecessor with a 5MP resolution texture camera, enhanced accuracy, and 3 infrared VCSEL projectors for more photorealistic textures and better quality data. Its wide scanning area and adjustable working distance make it suitable for various scenes and objects, both small and large, in narrow or wide spaces.
Hybrid Light Source
The EinScan H2’s Dual Light source improves scanning efficiency with its LED light offering fast 3D scanning with accurate, high-quality data generated. With scanning speeds of 1,200,000 points/s, accuracy up to 0.05mm and a point distance up to 0.2mm the EinScan H2 is an efficient 3D scanning tool that can revolutionize workflows. Infrared VCSEL is ideal for capturing dark surfaces and for brightly-lit environments including outdoor scanning with accuracies up to 0.1mm with a point distance up to 0.2mm.
Ultra-Wide FOV and Adjustable Working Distance
Offering an adjustable working distance adjustment from 200mm to 1500mm, EinScan H2 is able to adapt to narrow or wide scenes and objects of various sizes with a FOV (Field of View) up to 780mm x 900mm.
The Shining 3D EinScan H2 offers flexibility in scanning volume to capture large-sized objects quickly.
For more information: www.einscan.com
