3D CMM Scanning Added To Optical Shaft Measurement Machine
SYLVAC recently unveiled the integration of the Renishaw SP25M tactile 3D scanning probe into its SYLVAC-SCAN S145 optical measurement machine. This upgrade enhances the machine’s capabilities, providing a multi-sensor solution that detects features beyond optical reach. Specifically designed for measuring holes and slots in cylindrical components, the enhanced system is identified as the SYLVAC-SCAN S145 P.
All in one solution: Complete measurement with a single system, seamless integration with combined sensor measurements, easy programming thanks to user-friendly functions, full touch probe scanning capability for measuring form, interchangeable probe stylus increased access, automated probe qualification routine and typical measurements include : hole and slot size, location and form, roundness, radial and axial runout.
Cost Savings at Every Turn: The non-contact machine is designed for the measurement of large cylindrical parts up tp 100kg. The machine can handle virtually all measurements (static and dynamic) on cylindrical parts up to 145mm wide and 615mm long. With a complete 2D part scan taking less than 3 seconds, users can reduce inspection time, minimize scrap, and increase overall productivity.
Intuitive Operation: Easy operation right at the workplace with the new touch screen control panel. The dynamic LED indicator and intuitive Reflex SCAN+ concept provide real-time feedback on the measured part’s status (GO/NG) and operator messages. No prior programming is required—just a simple touch-button solution.
Precision and Efficiency: Experience exceptional precision with the no-contact machine’s bi-telecentric optical system and high-resolution CMOS camera. It features a precision sliding headstock with an integrated and protected daily standard, as well as a quick and hassle-free accessory changing system. The machine also includes integrated temperature sensors and exists with or without tilt system for true comprehensive thread measurement.
Key benefits
➤ Complete Measurement with a Single System
➤ Seamless Integration with Combined Sensor Measurements
➤ User-Friendly Programming
➤ Full Touch Probe Scanning Capability
➤ Interchangeable Probe Stylus
➤ Automated Probe Qualification Routine
➤ Measurements Include: hole and slot size, location and form, roundness, radial and axial runout
For more information: www.sylvac.ch
