Creaform Launches VXINTEGRITY NDT Software Platform
Creaform has announced the release of VXintegrity, the ultimate 3D scanning solution for surface damage assessment. Designed specifically to respond to the challenges facing industrial assets owners and NDT service companies, the new software platform contains four different modules, intended to tackle any surface analyses, as well as simple metrology applications.
Making it possible to measure up to 80 times faster than manual measuring tools, the new VXintegrity software platform, combined with Creaform’s 3D scanners, represents the optimal solution to the current shortage of experienced technicians and aging and/or damaged infrastructures. Moreover, this user independent technology requires little training and few certifications, which means that technicians can be up and running faster than with other techniques.
This complete NDT solution also enables industrial asset owners to have full confidence in the evaluation results and make the best maintenance decisions with the best available data, as it can accurately measure thickness loss on corroded, industrial, complex geometry such as elbows, nozzles, pressure vessel heads, tank floors and valves. With this software platform, a complete analysis of all types of surfaces is now possible.
The VXintegrity software platform regroups four different application software modules dedicated and optimized for specific industries’ challenges:
➤ Pipeline module (also known as Pipecheck): The safest NDT solutions for pipeline integrity assessment, this module is designed to provide corrosion, denting (mechanical damage), and wrinkle analyses.
➤ Aerospace module (also known as SmartDENT 3D): Ideal for the aerospace industry and for MRO companies, this versatile 3D scanning solution offers unmatched speed, ease of use, reliability and repeatability. Hailstorms damage inspection, flap and spoiler maintenance, aircraft incidents analysis and regulatory scheduled maintenance, this module can do it all.
➤ New Surface Damage module: Specifically created with power generation and heavy industry owners in mind, this module represents the only accurate and traceable NDT method to assess surface damage on complex geometries, of all shapes, size and materials.
➤ New Monitoring module: Guaranteed to the micron, this monitoring solution is an extremely accurate and noiseless NDT method used to compare damage progression through time, deformation analyses and other simple metrology applications. With its impressive report capabilities, this module is the best way to ensure the integrity and safety of any infrastructure.
“The metrology-grade 3D data generated through this software platform can precisely identify small thickness variation between inspections to compare damage progression through time, making it the best, and only, technique sensitive enough to do so on the market” insists François Lachance, Product Manager at Creaform. “In addition, these four industry-optimised modules are sure to open up new business opportunities for NDT service providers.”
For more information: www.creaform.com
