3D Scanner Captures Full Colour Models In High Resolution
At the recent Formnext industrial 3D printing exhibition in Germany Shining 3D launched its new Transcan C scanner based upon structured white light LED technology. The 3D scanner comes complete with a slide rail design allowing users to dynamically switch between two different scan ranges enabling both small and large part scanning.
Transcan C is a professional-grade 3D scanner, capturing exceptionally high resolution and accurate scans of objects of a broad range of sizes. The 12 Megapixel cameras produce rich and detailed colorful 3D models, authentically generating a digital replica of an object.
Ready-to-Use Dual Scan Range
The slide-rail design enables an easy switch of the scanning range between 150 mm x 96 mm and 300 mm x 190 mm meeting the needs of scanning objects of different sizes effectively.
Multi-Resolution Fusion
The Multi-Resolution Fusion Algorithm allows a mixture of 3 levels of resolution of high, medium or low in one project for complex scanning tasks, which highly improves efficiency without duplication of work.
High Color Fidelity
Two 12 MP color cameras are installed to capture a detailed 24-bit color map, replicating the authentic color of the physical object. Transcan C is the ideal solution to capture color 3D data for virtual display.
High-Accuracy Intelligent Operation
The compact design scanner produces high accuracy of 0.035 mm at its inner position, and of 0.05 mm at its outer position. These results are valuable to many applications for measurement. The scanning process is fully automatic with incorporated turntable. Combined with the scanning software’s stitching algorithm, this ensures the efficient acquisition of 3D data without manual intervention. The software interface guides the user through a simple operation process while providing powerful tools for the hassle-free optimization of the scan results.
