Verisurf Demonstrates Enterprise Inspection and Measurement Software for All Applications and Devices
At the CONTROL Exhibition in Stuttgart Verisurf Software will be demonstrating complete inspection and measurement solutions for Industry 4.0 enterprise applications. Universal compatibility with all measurement devices and any CAD/CAM software helps Verisurf close the digital loop between design, manufacturing, and quality verification.
âVerisurf’s no-code programming and powerful metrology tools make it easy and efficient to create a single inspection plan that can be executed consistently across the manufacturing enterprise using any available sensor device,â said David Olson, Director of Sales & Marketing for Verisurf. âThe software not only supports all devices but also operates them, providing a familiar interface for every user. This increases efficiency, reduces training time, and lowers overall software costs,â added Olson.
Verisurfâs commitment to a solution-based approach to metrology applications ensures the software keeps up with hardware advancements. Quarterly and annual software updates keep Verisurf in lockstep with new devices and CAD/CAM advances introduced by Mastercam, on which Verisurf is built. Verisurf was designed from the ground up with Model-Based Definition (MBD) at its core and is the only metrology software that can create an intelligent 3D CAD model and use it as the inspection nominal.
Among the booth demonstrations at Control will be a CMM running Verisurf with theRenishaw REVO 5-axis measuring system. Verisurf programs and drives the REVO 5-axis multi-sensor measurement system, which uses synchronized motion and 5-axis measurement technology to minimize the dynamic effects of CMM movement at ultra-high measurement speeds.  This improves agility and accuracy while reducing measurement cycle time by 15% to 50%. The REVO multi-sensor probe and stylus changing capability has solutions for 2D and 3D continuous scanning, surface finish inspection, ultrasonic thickness measurements, and more.
Laser scanner and optical tracker solutions, optimized by Verisurf, will also be demonstrated, as well as the popular Master3DGage turn-key PCMM. Ideal for commercial metalworking, performance engine building, and educational use, the Master3DGage is a bundled solution with everything users need to be productive, right out of the box, including hardware, software, and accessories.
