The CMM Retrofit as an Alternative to a New CMM Purchase
When your CNC CMM fails, how should the business decide whether it is worth considering a retrofit or whether a new CMM machine should be purchased?
What Is A Retrofit?
When a CMM measurement machine breaks down, there are usually two options available: to purchase a new CMM or recondition and upgrade the existing one by considering the retrofit of the existing CMM measurement machine.
Offering a retrofit to your CNC CMM regenerates both its hardware and software systems. It restores its original performance and allows addition of a whole range of functionalities: connecting new types of sensors, increasing overall precision and productivity, reducing measuring cycle time.
A retrofit generally refers to an upgrade by replacement of a CNC CMMās electronic equipment, mainly its controller unit and associated components. Considering a software upgrade at the same time is not mandatory but is usually requested to get full benefits of the newly installed unit.
Purchasing New CMM
A customerās measurement needs may have changed. If tighter tolerance levels are required and they lie outside of the capability of the current CMM, then a new CMM will need to be purchased as no amount of servicing will achieve the enhanced accuracy level required.
Before investing in a new CMM machine, it is worth isolating the problem by working through the following three areas to determine the most cost-effective path for the business.
Retrofitting a CMM Can Be Cost-Efficient Solution
Replacing parts provides a quick and easy solution to a fully functioning CMM measurement machine as it:
⤠Enhances performance
⤠Extends the life of a CMM
⤠Provides reliable and accurate measurements
⤠Becomes easy to use
⤠Ensures cost-effectiveness
CMM Software
Legacy software may have limitations. The opportunity to retrofit and upgrade to new software should:
⤠Get the best available features on the market
⤠It should be easy to use and program
⤠Be in a universal programming format
⤠Work across all brands of CMM (not tied to one specific brand)
⤠Allow the operator to work efficiently across machines
⤠Take data in any format and be able to use it
⤠Provide consistent results between devices
⤠Efficiently manage large data sets
⤠Show errors in measurements and show how errors can be corrected,
⤠Provide clear informative reports that can be pushed to other departments in the production process,
⤠Adapt to changing needs of the organization and its measurement requirements.
New software should not only replace old software on a CMM machine but also upgrade it; providing a new lease of life for the CMM by making the machine ready for the future by being faster and more efficient, at a fraction of the cost of a new machine.
Benefits of a CMM Retrofit?
There are quite a few benefits to be gained from a CMM retrofit:
⤠It enhances performance
⤠It extends the life of a CMM
⤠It provides reliable and accurate measurements
⤠It is easy to use
⤠It is a scalable machine
⤠It is cost effective
In conclusion, with a retrofit you are not only repairing, but also upgrading the CMM machine, effectively spending less to get a machine with improved performance and capabilities.
For more information: www.metrologic.group
