Bruker Alicona Introduces FocusX Shopfloor Enclosure
Bruker Alicona has annouced it’s taking a further step to facilitate quality assurance in production by introducing the Shopfloor Enclosure for
the FocusX, the ultimate solution for achieving the highest precision and reliability directly on the shopfloor.
The FocusX Shopfloor Enclosure offers unparalleled protection and precision to meet the demanding needs of modern production environments. The Shopfloor Enclosure is meticulously engineered to protect the FocusX from environmental factors such as airborne particles, dust, and spray water or oil. This robust enclosure ensures that the FocusX can operate at peak performance even in the most demanding conditions.
FocusX For Production Measuring
The FocusX is a groundbreaking device transforming quality assurance with its Advanced Focus-Variation technology in a smart package. This technology enables precise measurement of micro-geometries and surface roughness on smooth and reflective surfaces using a single sensor. The FocusX is designed to be compact and versatile, making it ideal for on-site use in production environments. Its adaptability is further enhanced by the Real3DUnitX, which provides five-axis capability, ensuring every surface of your component is accessible and measurable.
The Real3DUnitX, a connectable rotation and tilting unit offers unparalleled accessibility and automation options. With the Real3DUnitX, the FocusX can perform 360° measurements, allowing for thorough inspections using CAD files for comparison. This upgrade is particularly valuable for analyzing complex geometries that were previously difficult to measure. The Real3DUnitX enhances the versatility of the FocusX, making it an indispensable tool for various industries, including cutting tools, electronics quality control, and medical technology.
The Shopfloor Enclosure features an integrated workstation equipped with two monitors, a keyboard, and a mouse holder, providing a complete setup for operators. The enclosure’s main switch controls the entire power supply, allowing the system to be easily turned on or off with a single switch. This feature simplifies the operation and ensures that the FocusX is always ready for use.
Thermal management is a critical aspect of the Shopfloor Enclosure. It features two separate chambers that thermally isolate the system from the control server. Each chamber is equipped with two fans, ensuring optimal air flow and preventing overheating.
The Shopfloor Enclosure is rated IP 53. This rating indicates the level of protection the Shopfloor Enclosure provides against dust and water. The enclosure can withstand splashing water, such as from cleaning processes or accidental spills, without compromising the FocusX’s functionality. The enclosure’s robust construction and high-quality materials make it a durable and reliable solution for any production facility.
The Shopfloor Enclosure has an approximate weight of 270 kg, a height of approximately 2000 mm, a width of 750 mm, and a depth of about 950 mm. It is equipped with four adjustable feet to compensate for uneven surfaces, ensuring stability and ease of installation. The enclosure’s mobility allows for easy relocation of the FocusX within the facility. Simply turn off the main switch, unplug the power cable, and use a forklift or pallet jack to transport the system.
Marco FĂĽrpass, the project manager of the Shopfloor Enclosure at the Bruker Alicona R&D department, emphasized the specific needs of production metrology: “In today’s fast-paced manufacturing environments, precision and reliability are paramount. The Shopfloor Enclosure addresses these needs by providing robust protection and ensuring that the FocusX can deliver accurate measurements even in the roughest conditions. This enclosure is a testament to our commitment to advancing production metrology and supporting our customers in achieving the highest standards of quality.”
The concept behind the Shopfloor Enclosure is to enable customers to either plan and teach-in the measurement on-site or offline just once, allowing operators to use the Shopfloor Enclosure directly in production. This setup ensures a standing workstation that integrates seamlessly into the production process, enhancing efficiency and ease of use for operators.
