Research Team Detects Additive Manufacturing Defects in Real-Time
A research team at the University of Virginia, has made new discoveries that can expand additive manufacturing in aerospace and other industries that rely on strong metal parts.
The peer-reviewed paper was recently published in Science Magazine and addresses the issue of detecting the formation of keyhole pores, one of the major defects in additive manufacturing technique using the laser powder bed fusion process (LPBF).
Introduced in the 1990s, LPBF uses metal powder and lasers to 3D print metal parts. But porosity defects remain a challenge for fatigue-sensitive applications such as aircraft wings. Some porosity is associated with deep and narrow vapor depressions which are the keyholes.
The formation and size of the keyhole is a function of laser power and scanning velocity, as well as the materialsâ capacity to absorb laser energy. If the keyhole walls are stable, it enhances the surrounding materialâs laser absorption and improves laser manufacturing efficiency. If, however, the walls are wobbly or collapse, the material solidifies around the keyhole, trapping the air pocket inside the newly formed layer of material. This makes the material more brittle and more likely to crack under environmental stress.
Tao Sun, associate professor of materials science and engineering and his team developed an approach to detect the exact moment when a keyhole pore forms during the printing process. âBy integrating operando synchrotron x-ray imaging, near-infrared imaging, and machine learning, our approach can capture the unique thermal signature associated with keyhole pore generation with sub-millisecond temporal resolution and 100% prediction rate,â Sun said.
In developing their real-time keyhole detection method, the researchers also advanced the way a state-of-the-art tool, operando synchrotron x-ray imaging, can be used. Utilizing machine learning, they additionally discovered two modes of keyhole oscillation.
“Our findings not only advance additive manufacturing research, but they can also practically serve to expand the commercial use of LPBF for metal parts manufacturing,” said team member Anthony Rollett from Carnegie Mellon University and mechanical engineering professor. Rollett.
âPorosity in metal parts remains a major hurdle for wider adoption of LPBF technique in some industries. Keyhole porosity is the most challenging defect type when it comes to real-time detection using lab-scale sensors because it occurs stochastically beneath the surface,â Sun said. âOur approach provides a viable solution for high-fidelity, high-resolution detection of keyhole pore generation that can be readily applied in many additive manufacturing scenarios.â
For more information: www.engineering.virginia.edu
