Optical Shop Floor Measuring Machine Launched
In the world of machining, every detail counts. Having reliable and accurate instruments in your production process is essential to ensure the quality of your finished products. In response to this need, Metrios measuring systems were born.
The Metrios range offers a wide choice of models and degrees of accuracy, making it the perfect measurement solution for all types of components: from automotive, aerospace and medical to semiconductors and micro-components. With Metrios, it is possible to check dozens of dimensions in a matter of seconds with a single program, both single-piece and multi-pieces.
Shop Floor Measurements
The new Metrios 332 optical measuring machine was born from the need to meet the demand of all component manufacturers who do not want to give up the precision guaranteed by multi-sensor machines, but who at the same time seek the speed and simplicity that only modern measuring systems can offer. Metrios 332 represents the perfect synthesis of all these features, combining ease of use, speed, completeness, and precision in a single compact and powerful solution built for operating on the shop floor.
Advanced Features For Optimal Performance
300 x 300 mm X-Y measuring range: A wide measuring range combined with high part clearance enables the Metrios 332 system to measure a wide range of parts, offering unparalleled flexibility and versatility.
Up-to 20 kg stage loading: A high load capacity on the stage allows even heavier parts to be placed on the working area.
Wide-field sensor detects the parts and measures at maximum speed: Achieve fast and reliable results due to the sensor that detects the parts on the stage and measures the required dimensions in a matter of seconds.
Ultra-high magnification sensor for uncompromising accuracy: The ultra-high magnification sensor can detect points in X-Y-Z even on the smallest details.
Unique comprehensive lighting system: Shields from environmental light and ensures accurate and reliable measurement results even on the most difficult-to-detect surfaces.
The Metrios 332 measurement system represents a breakthrough in the metrology industry, thanks to its ability to combine the simplicity and speed of automatic optical measurement, with the completeness and accuracy of multi-sensor machines directly in the production environment. It is, therefore, an indispensable tool for workshops and manufacturers who want to maintain high quality standards and be always competitive in the market.
For more information: www.metrios.com
