MeshInspector Software Platform Transforms 3D Scans
Prepare Scan Data for comparison
If the data obtained from the 3D scanner isn’t already a solid model, MeshInspector is the ideal solution to transform scanned data into a solid model. The software seamlessly converts scan data into a precise solid model, giving accuracy needed for in-depth analysis.
Align Objects with Precision
Attain precise alignment of multiple scans with our flexible alignment options. Choose between automatic alignment or manually selecting reference points on each model, providing the tools for accurate comparisons. Additionally, users can designate which object is considered ‘floating’ and which is ‘fixed,’ enhancing control over the alignment process.
Visualize Differences
Explore the differences between two models with the innovative distance compare tool. Utilize a color distance map to meticulously analyze surface disparities such as protrusions, bulges, dents or slots. The compare tool empowers users to inspect the quality of printed 3D model in comparison to the original CAD design, helping identify even the most minor deviations to meet the highest standards.
Download PDF Reports
Access comprehensive PDF reports containing detailed information for thorough analysis. The reports provide insights into distance comparisons, visual comparisons, and average statistics, enabling informed decision-making to uphold project precision and compliance with industry standards. Collaborate effectively by easily sharing these reports with an extended team.
For more information: www.meshinspector.com
