Marposs Sets a New Standard in Tool Measurement
In today’s highly competitive manufacturing environment, efficiency, accuracy, and reliability are more critical than ever. Tool setting plays a pivotal role in achieving these goals, and Marposs has announced the introduction of the ML3G, a non-contact tool measurement system that sets a new standard in tool control directly on the machine.
Protecting Tools and Enhancing Accuracy
Unlike traditional mechanical tool setters, the ML3G operates without physical contact. By measuring tools through the interruption of a laser beam, ML3G eliminates the risk of damage to small, fragile, or coated tools. This non-contact method also allows measurements at real cutting speeds, even at thousands of RPM, ensuring accurate results that are unaffected by run-out or dynamic length variations.
The ML3G is designed for flexibility, capable of measuring a wide range of tools and performing multiple types of inspections ML3G reduces manual errors and streamlines production processes.
Advanced Features for Modern Manufacturing
The ML3G introduces several innovations:
Powerful Processor: Enhances measurement speed and supports advanced controls,.
New Shutter Design and Fixing System: Ensures perfect sealing and simplifies maintenance.
Integrated Air Blower: Efficiently cleans tools during measurement.
Reinforced Mechanical Structure: Guarantees excellent performances even under the harshest operating conditions.
These features combine to provide a reliable, durable, and highly accurate tool measurement solution suitable for modern manufacturing environments.
Versatility and Reliability in Every Operation
The ML3G is engineered to deliver fast, precise measurements while withstanding challenging conditions, including coolant exposure and chip contamination. Its versatility is evident in its multiple configurations, offering four lengths and three mounting options to suit a wide range of machine setups. Beyond tool pre-setting, ML3G can also perform tool breakage detection, integrity verification, and cutting edge profile scanning, helping manufacturers reduce scrap and increase production efficiency.
With the ML3G, Marposs continues its tradition of innovation in precision measurement. By combining non-contact technology, advanced processing, and robust construction, ML3G delivers exceptional speed, accuracy, and reliability. Manufacturers benefit from improved productivity, reduced manual errors, and minimized tool damage, making ML3G an indispensable solution for modern machining operations.
For more information: www.marposs.com
