LiDAR Scanners Deliver Precise 3D Contour Measurements
Leuze is broadening its sensor portfolio by integrating cutting-edge LiDAR technology, introducing the new ROD 300 and ROD 500 series of laser scanners. These advanced devices are designed to deliver precise contour measurement and optimized navigation for automated guided vehicles (AGVs), meeting the increasing demands of modern production and logistics.
Precision in Contour Detection
When it comes to detecting contours on conveyor systems or AGVs, accuracy and reliability are critical. The ROD 300 series is engineered to deliver precise contour detection even in fast-paced production and logistics environments. With high scanning rates and superior angular resolution, these laser scanners ensure dependable performance in demanding industrial applications. Meanwhile, the ROD 500 series is specifically optimized for navigation, providing unparalleled precision in guiding AGVs.
A key feature of these laser scanners is their integrated window monitoring system, which detects contamination on the optics window. This function supports predictive maintenance strategies, ensuring high system availability and reducing unexpected downtime.
Uncompromising Performance and Durability
The ROD 300/500 series operates at scanning frequencies of up to 80 Hz, ensuring that even rapidly moving objects are detected with high accuracy. With an angular resolution of 0.025° at 10 Hz, the ROD 500 series excels in contour determination, regardless of whether the surface is highly reflective or matte. These laser scanners are highly versatile and compatible with a wide range of production processes.
Designed for durability, the ROD 300/500 series features a robust aluminum base and a built-in laser diode, offering protection against external environmental factors. With an IP67-rated enclosure, these sensors are resistant to dust and moisture and can operate in extreme temperatures ranging from -30°C to +60°C. This makes them ideal for applications in cold storage environments as well as high-temperature manufacturing settings, such as battery production.
Seamless AGV Integration for Natural Navigation
Beyond contour detection, the new laser scanners play a vital role in AGV navigation. The ROD 500 series creates highly accurate environmental maps, enabling seamless and collision-free AGV movement through natural navigation. This functionality is particularly beneficial in logistics operations, where precise material storage mapping is crucial for efficiency.
Additionally, the compact form factor of these laser scanners (80 x 80 x 80 mm) ensures easy integration into AGVs, even within limited installation spaces. This adaptability enhances their suitability for a broad spectrum of mobile vehicle applications.
With the introduction of the ROD 300 and ROD 500 series, Leuze continues to drive innovation in LiDAR technology, delivering high-performance solutions that enhance industrial automation and logistics efficiency.
For more information: www.leuze.com
