Laser Optics Are Key To Recent Sustainable Energy Breakthrough
ZYGO Corporation holds a prominent position in the recent success in the area of laser fusion, which opens up the possibility of virtually unlimited supplies of low-carbon, low-radiation energy. The current reliance on fossil fuels has obvious implications for ecosystems and climate, and ZYGOâs ongoing partnership with Lawrence Livermore National Laboratoryâs (LLNLâs) National Ignition Facility (NIF) in the United States is helping to bring safe, virtually unlimited carbon-free energy one step closer to reality.
NIF scientists are using laser fusion to harness the energy that powers the stars, with the goal of producing more energy than it consumes in a sustainable reaction called âignition.â Existing nuclear reactors used across the world split atoms to produce energy (and as a by-product produce radioactive waste). NIF fuses together atoms from easily obtainable materials commonly found across the globe.
NIFâs scientific breakthrough generated more than 10 quadrillion watts of fusion power for a fraction of a second. This is roughly 700 times the generating capacity of the entire U.S. electrical grid. NIF is continuing its work to achieve ignition and create a viable source of power.
ZYGO is proud to be playing a pivotal role in bringing clean, sustainable energy closer to reality, manufacturing nearly all the flat specialty optics used in the NIF laser. Getting the reactions going is not the problem; the trick is getting more energy out of the fusion process than you put in. To this end, NIF houses more than 7,000 ZYGO custom optics, including 3072 amplifiers (described by NIF as âthe heart of the systemâ) that amplify a pulse of photons into 192 laser beams â focusing them on a target smaller than a pencil eraser.
When the beams hit the small target, it compresses the fuel to 100 times the density of lead and heats it to 100 million degrees Celsius, hotter than the center of the Sun. Heating the target in this way generates an electrically charged gas (plasma), and in the plasma, electron particles are stripped out of atoms, leaving the parts known as atomic nuclei. These can fuse together, generating energy in the process. (See video here).
ZYGO worked closely with LLNL to develop optical manufacturing processes which support high-volume production of meter class, laser-grade optics for the NIF laser, including amplifier slabs, turning mirrors, vacuum windows, continuous phase plates, gratings and main debris shields. The optics used in NIFâs 192 Beamslines must have extremely low surface defects in order to achieve higher fluences.
