Ladybug6 Camera Provides High Accuracy 360° Spherical Image Capture
Teledyne FLIR has announce that its all new Ladybug6 360-degree camera is now in full production.
Ladybug6 is the leading high-resolution camera designed to capture 360-degree spherical images from moving platforms in all-weather conditions. Its industrial grade design and out-of-the-box factory calibration produces 72 Megapixel (MP) images with pixel values that are spatially accurate within +/- 2 mm at 10-meter distance. As the newest member of our field-proven Ladybug series, the Ladybug6 builds on the Teledyne FLIR machine vision heritage with increased image resolution, enhanced on-board processing, and robust IP67-rated connectors. Support for additional Global Navigation Satellite Systems and advanced APIs, combined with hardware inputs, enable precise camera settings and trigger control.
“We are excited to announce that our newest Ladybug camera is in production now and units are shipping immediately. The interest expressed by so many of our long-term customers has been astounding with order commitments made months in advance,” said Mike Lee, Senior Product Manager at Teledyne FLIR. “For applications that require high accuracy imaging like asset inspection, and high-definition mapping, the Ladybug6 gives users precision trigger control and resolution in a field-proven format unmatched by other manufacturers.”
Ladybug6 is the industry’s leading high-resolution camera designed to capture 360-degree spherical images from moving platforms in all weather conditions. Its industrial-grade design and out-of-the-box factory calibration produce 72 Megapixel (MP) images with pixel values that are spatially accurate within +/- 2 mm at a 10-meter distance.
For more information: www.teledyneimaging.com
