In-Line X-ray CT Inspection Systems Leverage AI Technology
OMRON Corporation has developed three models of CT automatic X-ray inspection systems that enable industry-leading high-speed 3D inspection namely the VT-X750-XL, VT-X850 and VT-X950. The new machines are being released sequentially from February 2024 onward.
Recently, the amount of information used in the world is rapidly increasing with the expansion of user access to generative AI and data centers for interactive artificial intelligence and the development of 5G/6G communications, and the further miniaturization of semiconductors used for these applications is progressing. In particular, miniaturization technology has advanced to a high level of technological difficulty, and along with miniaturization, the need for packaging using integration technology called chiplets will increase in the future. Unlike conventional flat designs, chiplets require more precise inspections as their structures become more complex through three-dimensional mounting.
The automotive industry, in particular, is becoming more environmentally friendly with the development of xEVs, and integrated EV modules that combine multiple functions, such as eAxle. Efforts are underway for 3D packaging to realize further space saving and higher efficiency in module design. Products using 3D packaging, which are being introduced in a variety of industries, are difficult to determine if they are good using conventional 2D-X-ray inspection systems with transmission images, making it a major challenge to achieve both productivity and quality. At the same time, there is a growing need for stable production at multiple sites in preparation for the duplication of supply chains, and the establishment of a production system that is not overly dependent on human interaction.
In response to these needs, three newly commercialized models of automatic CT-type X-ray inspection systems combine OMRONâs proprietary control and image processing technologies to achieve high-speed, high-precision inspection. The combination of continuous imaging technology*5 and a high-sensitivity camera through seamless control of the equipment achieves high-speed imaging of high-resolution, easy-to-distinguish 3D images.
In addition, high-speed generation of modeling using state-of-the-art 3D inspection technology, which is also used in medical CT scanners, enables in-line quality inspection, which has been difficult to achieve at manufacturing sites. Utilizing proprietary AI technology, the system automatically optimizes the setting of inspection imaging conditions and automates the creation of inspection programs that were previously difficult only for skilled engineers and technicians.
OMRON has been contributing to the improvement of productivity at manufacturing sites by leveraging its strength in control technology under the Innovation Concept innovative-Automation. We will continue our efforts to improve productivity and to evolve into a sustainable at manufacturing site. OMRON will enrich the future for people, industries and the globe by innovative automation.
Value Proposition
Contributing to stabilization of production quality in semiconductor packages and power semiconductors with industry-leading high-speed 3D automated inspection:
Since the shape and constituent materials vary depending on the industry and inspection target, the output characteristics of the X-ray source and inspection method are optimized for each model. By combining OMRONâs proprietary control and image processing technologies, the solder quality of ÎŒBump and C4Bump used in 3D mounting of each semiconductor package can be visualized. The imaging technology supports the miniaturization and thinning of semiconductor devices. The 3D modeling of solder used for boards and semiconductors from X-ray transmission images has been sped up by approximately 30%. In addition, inspection result data using the SEMI communication standard (SECS/GEM) can be linked to a production control system to realize quantitative condition monitoring of the production process. High-speed inspection that does not place a burden on the production line improves semiconductor production yield.
Advanced image processing using proprietary AI technology automates inspection settings to determine good/defective products:
The VT-X series is the first in-line inspection system that uses AI technology to determine whether a product is good or defective by processing captured images using deep learning. The AI automatically determines the soldering condition of each product based on the generated 3D model. This automates the creation of inspection programs without relying on the specialized skills of skilled workers in image processing.
First in the VT series to support clean rooms and automate setting changes according to production items:
The X950 is the first in the VT series to support clean rooms for mid-process semiconductors where wafer-to-wafer bonding processes occur. The X950 is also equipped with a function that automatically changes inspection settings to accommodate sudden changes in production items due to fluctuating demand. The system automatically changes conditions by referencing measurement points and inspection settings registered in advance in the production control system that are appropriate for each production item. This reduces start-up losses and re-setting of inspection settings. In addition, as with the conventional VT series, the VT series is equipped with a conveyor-based automatic loading/unloading function, contributing to automation and manpower saving in the manufacturing process.
For more information:Â www.omron.com
