High-Precision 3D CMM Scanning with Micro-Epsilon’s scanCONTROL Sensors for Industry 4.0
Laser profile scanners from Micro-Epsilon’s scanCONTROL series are transforming coordinate measuring machines (CMMs) into smart, connected quality control systems aligned with Industry 4.0 objectives. These advanced sensors enable high-resolution 3D point cloud generation, supporting both quality assurance and reverse engineering in modern manufacturing environments.
A standout feature is the dedicated CMM trigger output, which ensures precise synchronization between the measuring position and measurement timing. Unlike conventional triggering methods that may introduce latency, this real-time coordination allows for ultra-accurate surface capture—even during dynamic, multi-directional scanning movements. The result is improved measurement fidelity and reduced uncertainty in complex inspection tasks.
Supporting smart factory requirements, scanCONTROL sensors deliver raw data at high speed, up to 10 million points per second, while conforming to the GigE Vision standard for seamless integration into digital manufacturing systems. The compact, lightweight design with an integrated controller enables space-saving installation and supports high-speed operations essential for automated and inline inspection processes.
Designed with flexibility in mind, the scanCONTROL product range accommodates a variety of table configurations, part sizes, and materials. Extensive interface options allow the sensors to communicate effortlessly with a wide array of CMM control systems, facilitating their deployment in fully connected, data-driven production lines.
By combining high-speed precision scanning with robust connectivity and integration capabilities, Micro-Epsilon’s scanCONTROL sensors provide a powerful metrology solution that supports real-time decision-making and closed-loop quality control—key pillars of the Industry 4.0 paradigm.
