Granite Column Tool Presetter Guarantees and Maintain Maximum Accuracy
The new E346V+ Lyndex-Nikken Tool Presetter represents a massive update over the entry level E346i Tool Presetter. Designed to be bench mounted, with optional base available, the E346V+ features an electro-welded structure in de-tensioned steel along with a unique solid granite column and base to guarantee and maintain maximum accuracy.
The precision spindle system is fully interchangeable and can accommodate cartridges for all types of machine tapers covering HSK, ISO, VDI, BT, etc. Also provided as standard on the V+ is vacuum tool clamping for ISO/BT 7/24 type tool shanks.
Measuring range: Diameter max 360 mm (radius 180 mm); height max 460 mm.Â
Innovative Automatic Measuring Routine
The E346V+ features a new and innovative automatic measuring routine allowing the operator to simply rotate the tool through 360 degrees after which the software captures and locks the maximum measured radius/diameter and length values of all the cutting edges. The software is displayed and interacted with via a 15” TFT (Thin Film Transistor) touch screen mounted vertically for easy viewing and operation. Simple icon and graphically driven menus enable the operator to quickly and intuitively manage all tool measurement and inspection modes, in addition a range of auxiliary capabilities are available such as creating CNC Machine origins and tool sets.
The Presetter features numerous outputs including several USB ports and network capability allowing for the transfer of post processed tool offset data from the tool management system, via a network or memory stick, to the numerical control of individual machine tools.
For more information: www.lyndexnikken.com
