Gentec-EO Launches New High-Power Laser Power Detector
Gentec-EO launches the HP60A-15KW-GD-QBH power detector series for measurement of fiber lasers with power up to 15kW. The new laser power detector is ideal for those in need to measure average laser power for burn-in tests, during long periods of time or even quickly in the field with the simplicity of connecting a fiber laser output directly to the detector.
The HP60A-15KW-QBH series is calibrated to NIST standards and has damage thresholds up to 80 kW/cm2.
The user simply needs to connect its QB or QBH fiber output and adapted water lines and is ready to measure. There are 2 outputs on this product: DB15 and USB. The DB15 cable allows to view the measurements on a Gentec-EO display device. Using the USB connection with a PC, the user can view and acquire data, or integrate the signal in a control feedback loop.
EO’s high-accuracy laser beam measurement instruments help engineers, scientists and technicians in all sorts of laser applications from the factory to the hospital, laboratory and research center. Learn about our solutions for these measurement types:
The detector series is less sensitive to variations in water cooling temperature than any other high power water-cooled meter on the market providing a stable reading. A wireless connection option is also available with these detectors, so the high power room can be closed and to use less cables for safer measurements. Check out Gentec-EO’s BLU award-winning technology if you are interested in this.
The HP60A-15KW-GDQBH generates zero back reflection to your environment and negligible back reflections to the fiber output connected to the detector thanks to the gold cone absorber design inside of it. With the technology used in this product series, Gentec-EO has the capability to design custom products that measure much higher laser power levels than 15 kW.
For more information: www.gentec-eo.com
