Evolution Toward Multi-Sensor Measurement Reflects a Broader Transformation in Industrial Metrology
As manufacturing continues to demand higher precision and greater flexibility, the limits of single-technology measurement systems are becoming increasingly apparent. Today’s components often combine complex external geometries with features that require deeper, point-based verification.
In this scenario, multi-sensor optical systems represent a natural evolution, seamlessly the speed of optical measurement with the precision of tactile probing.
Optical Measurement at The Core
VICIVISION has established itself as a leader in high-speed optical measurement, particularly for turned and cylindrical components. By capturing the full profile of a part in a single acquisition, VICIVISION systems enable fast, repeatable, and non-contact inspection directly on the shopfloor.
Diameters, lengths, radii, threads, and complex profiles can be measured within seconds, allowing manufacturers to significantly improve inspection efficiency while reducing operator dependency.
However, as component complexity increases, some features require additional verification beyond what optical systems alone can provide.
Integrating Tactile Precision
The integration of tactile probes within optical systems enhances measurement capabilities without compromising speed.
In a multi-sensor configuration, optical measurement provides a complete overview of the component, while the tactile probe is used to verify critical features, such as internal geometries, specific reference points, or areas less accessible to optical detection.
This combination allows manufacturers to:
- Preserve the speed and efficiency of optical inspection
- Add targeted high-precision verification
- Eliminate the need for secondary measurement systems
The result is a more complete and adaptable inspection strategy.
Single Integrated Measurement Environment
One of the key advantages of VICIVISION-oriented multi-sensor systems is the ability to operate within a single measurement environment. Instead of moving parts between different machines, operators can perform both optical and tactile measurements in one setup. This reduces handling, minimizes alignment errors, and improves overall repeatability.
Moreover, automated measurement routines can seamlessly integrate both technologies, ensuring consistent results with minimal operator intervention.
Supporting High-Performance Manufacturing
In industries such as automotive, aerospace, and precision engineering, the demand for reliable and efficient measurement solutions continues to grow.
VICIVISION systems, enhanced by multi-sensor capabilities, enable manufacturers to accelerate inspection cycles, improve process control and adapt to increasingly complex components.
By combining speed with precision, these systems support consistent quality without compromising productivity.
From Inspection to Process Control
Measurement is no longer limited to final inspection, it is becoming an integral part of process control.
VICIVISION systems provide real-time feedback that can be used to adjust machining parameters, compensate for tool wear, and maintain dimensional stability. The addition of tactile data further enhances the reliability of this feedback, enabling more informed and precise decision-making. This integrated approach transforms metrology into a strategic tool for continuous process optimization.
By combining vision-based inspection with tactile precision, VICIVISION extends the capabilities of optical measurement, offering a more complete and flexible approach to dimensional control.
As manufacturing becomes increasingly complex, the ability to integrate speed, accuracy, and adaptability within a single system will be essential and multi-sensor solutions will play a central role in meeting this challenge.
By combining vision with tactile precision, manufacturers can achieve a more complete understanding of their components, ensuring quality, efficiency, and competitiveness in an increasingly demanding industrial landscape.
For more information: www.vicivision.com
