Entry-Level Dual Surface Measurement Device Launched
Mahr is expanding its portfolio of manual surface measuring devices with the MarSurf SD 140 AG 11, which can check both roughness and contour features – in just one measuring run. The measuring station offers easy handling and reliable quality assurance thanks to its high level of functionality. It is therefore also suitable as an entry-level model for stationary surface metrology.
The heart of the MarSurf SD 140 AG 11 is the newly developed tactile probe system. This can record the measured values for roughness and contour at the same time, which the software then evaluates separately. The probe arm measuring range covers 10 mm (100 mm probe arm) and 25 mm (200 mm probe arm), the measuring force from 0.7 mN to 30 mN can be set via software.
Users also save time with the probe system’s tool-free probe arm quick-change function, which allows them to quickly switch to a different measuring task without having to recalibrate the probe arm. The electronic probe arm recognition and automatic probe force selection offer you even more safety. This is because the correct (contacting) force is always guaranteed when changing between several probe tips.
The MarSurf SD 140 AG 11 also offers a defined start position with an aligned axis. The clamping system with its 390 x 450 mm mounting plate and 50 mm hole pattern allows a wide variety of workpiece holders and clamping devices to be used flexibly and quickly.
For more information: metrology.mahr.com
