Control Expo 2025 Preview #4
The 37th edition of Control, the world’s leading trade fair for quality assuranceis, set to take place from May 6–9, 2025, at Messe Stuttgart, Germany. This flagship event will bring together over 900 exhibitors from around the world to present the latest innovations in metrology, materials testing, analytical instrumentation, sensor technology, and quality assurance software. Across four expansive halls, visitors will experience firsthand the cutting-edge solutions that are shaping the future of industrial production, from high-precision measurement systems and inline inspection technologies to fully automated QA processes. As manufacturers continue to embrace digitalization and smart factory concepts, Control 2025 will serve as a vital platform for discovering new ways to enhance efficiency, ensure product quality, and future-proof operations.
New Approach To Wall Thickness Measurement
The MiniTest FH is stated as the new measure for precise wall thickness measurement by ElektroPhysik. The portable measuring device combines robust technology with digital intelligence – for applications in production, quality laboratories or demanding special environments. With measuring ranges of up to 24 mm and an innovative quick calibration function, the MiniTest FH enables precise zero-point calibration for every sensor and ball diameter in a matter of seconds. Intuitive operation, a clear 4.3″ display and an extensive database structure with up to 2 million storable measured values make the system an ideal partner in industry. The magnetostatic measuring method guarantees precise results of non-ferritic materials such as plastic, glass, aluminum or composite materials – even with complex geometries. Even hard-to-reach areas are easy to access with 90° sensor variants as well as automatic data transfer via USB, RS232 or Bluetooth.
Hall 7: Booth 7409Â Â For more information: www.elektrophysik.com
Triple Beam Laser InterferometerÂ
SIOS Meßtechnik’s triple-beam laser interferometric measuring system sets a new benchmark for precision, offering simultaneous, ultra-accurate measurements of length, pitch, and yaw angles. Engineered for flexibility and ease of use, it features integrated beam direction detection for straightforward handling and adjustment, while accommodating a variety of optical reflectors such as spherical and plane mirrors. With a permissible reflector tilt of up to ±12.5°, a compact sensor head design available in aluminum, stainless steel, or invar, and a beam distance of just 12 mm, the system is highly adaptable. OEM versions, specialized software, and vacuum-compatible models further broaden application possibilities, supported by optional beam deflection mirrors, extended interface options, and extensive triggering capabilities. To ensure measurement integrity, calibration software aligned with the latest standards is included, making this system a versatile solution for modern precision metrology.
Hall 5: Booth 5208Â Â For more information: www.sios-precision.com
LH Hybrid CMM – Perfect Combination of Coordinate and Gear Measuring Technology
The innovative Wenzel LH Hybrid 1210 4-axis measuring system redefines versatility by combining the precision of advanced gear metrology with the broad capabilities of a classic CMM in a single device. Featuring an integrated rotary table and a motorized tailstock, it efficiently measures gears, shafts, rotationally symmetrical, and prismatic components – even those with large dimensions. With a generous measuring range of 1200 x 2500 x 1000 mm, the system’s granite base plate and linear axes ensure thermally stable, highly accurate results. Designed for easy integration into existing production environments without the need for a special foundation, the LH Hybrid offers maximum precision, energy efficiency, and 4-axis technology for faster scanning and tool changes. Available in multiple sizes and offering flexible expansion options, it is a future-proof solution for evolving metrology needs.
Hall 5: Booth 5105Â Â For more information: www.wenzel-group.com
Accelerating Large-Volume Inspection and Real-Time Manufacturing Decisions
Setting the standard for large-volume inspection, tool-building, and industrial measurement, Verisurf delivers powerful, real-time solutions that keep manufacturing and assembly operations moving efficiently. Designed to quickly get operators up and running, Verisurf provides immediate access to live measurement data, enabling real-time decisions whether building large, complex assemblies directly to CAD models or performing precision field measurements. Its seamless integration with portable CMMs, laser trackers, and scanning systems ensures flexibility across a wide range of industrial environments, while its intuitive interface and CAD-based architecture make it easy to align measurement workflows with production goals. With Verisurf, users gain the confidence to validate parts, assemblies, and tooling with speed and accuracy, ensuring quality and reducing costly delays on the shop floor and in the field.
Hall 3: Booth 3508Â Â For more information: www.verisurf.com
Visometry To Unveil Next-Generation AR Quality Inspection
Visometry is set to unveil its latest innovation, Twyn 2.4, at Control 2025—a groundbreaking solution designed to deliver ultra-fast, highly flexible visual inspections powered by augmented reality (AR) technology. Building on the success of its previous versions, Twyn 2.4 introduces a major advancement with its new Assisted Deviation Detection feature. This capability automatically highlights discrepancies between physical parts and their corresponding CAD models, providing real-time visual feedback without the need for complex or time-consuming data configuration. The result is a significantly streamlined inspection process that enhances both speed and accuracy on the production floor. Visometry’s cutting-edge AR inspection solutions are making a growing impact across industries such as rail, heavy machinery, shipbuilding, aerospace, and welding.
Hall 3: Booth 3419Â Â For more information: www.visometry.com
