Control Expo 2025 Preview #3
The Control Exhibition in Stuttgart is the meeting place for all responsible for the quality of a product, process or service. Attention is focussed on technologies from the fields of machine vision, image processing, sensor technology, measuring and test technology, as well as software and data management. Below we highlight the third in a series of preview articles highlighting a few of the many new and innovative solutions that will be showcased at the Control Exhibition 6th – 9th May.
Optical High-Performance Shaft Measuring Machine Adds AI
The OptiShaft systems combine special measurement algorithms with optical technology developed by Adcole, the OptiShaft system delivers highly precise measurement results in seconds while guaranteeing unparalleled accuracy standards. Adcole has now updated the software of OptiShaft and is opening interfaces for upcoming AI functions. OptiShaft 135 offers precise shaft measurement through axial and rotational optical high-speed measurements on parts with diameters of up to 135 mm and lengths of up to 1200 mm. The measurement system features telecentric optics, collimated LED lighting technology, advanced edge detection technology, and automatic point generation, enabling easy feature extraction. The high-performance shaft measuring machine can be seamlessly integrated into existing quality control systems.
Hall 5 Booth 5416Â Â For more information: www.adcolegage.com
Intelligent Visual Inspection Powered by AR and AI – The Future of Manufacturing
CDMVision will announce SuPAR AI, the latest advanced augmented reality visual inspection software. SuPAR AI will transform traditional visual quality control with its AI-driven modules and AR technology. It leverages deep learning to improve accuracy and efficiency in manufacturing. With various specialized modules, SuPAR AI offers tailored solutions for diverse production lines. Designed to meet increasing manufacturing demands, SuPAR AI’s plug & play architecture allows users to select from multiple automated inspection models.
‘Hole Detection’, identifies discrepancies in drilled holes by comparing parts with their 3D CAD data to ensure correct positioning—enhancing production integrity. ‘Spot Welding Detection assesses weld quality and positioning using high-performance, low-impact deep learning networks, ensuring they meet quality standards. SuPAR AI also includes a stud inspection module, verifying the presence and correct installation of studs in parts ensuring readiness for further assembly, reducing errors and boosting efficiency. SuPAR AI increases inspection reliability and speed, enabling more parts to be inspected in less time. This scalability helps meet high production volumes without compromising quality.
Hall 9 Booth 9102Â Â For more information: www.cdmvision.com
Machine Vision Inspection Machine Technology Ads AI technologies
Machine vision inspection has become a cornerstone of quality control across industries, and with the advent of AI, this field is undergoing a
significant transformation. OPT is at the forefront of this revolution, integrating cutting-edge machine vision technology with AI technologies and machine learning algorithms. This fusion enables OPT to deliver highly efficient, cost-effective, and energy-saving custom solutions for quality control processes. OPT’s AI-powered vision inspection system detects microscopic defects, subtle flaws, and complex quality issues with remarkable precision and consistency. Through intelligent learning and adaptive optimization, the system continuously enhances its detection accuracy, effectively meeting the ever-evolving demands of modern production lines. OPT will showcase the solution of the 2D and 3D Combined Vision for Camera Housing Defect Detection By integrating 2D and 3D vision technologies, this solution enables comprehensive and precise inspection of camera housings. The 2D vision system specializes in detecting surface defects such as scratches, recognizing QR codes and barcodes, and identifying paint loss. Meanwhile, the 3D vision system accurately measures PIN height, verifies product flatness, ensures the correct number of screw holes, and detects incoming materials.
Hall 7 Booth 7401Â Â For more information: www.optmv.net
In the realm of precision manufacturing and metrology, the ability to securely and accurately hold intricate components is paramount. Enter the E-Chuck — a next-generation clamping solution engineered to meet the evolving demands of ultra-precise machining and measurement environments. The E-Chuck stands out for its exceptional precision and secure clamping capabilities, making it ideal for handling the most delicate and finely detailed parts. Its adjustable clamping force ensures that even the most fragile components can be held safely without risk of deformation or damage. This level of control is critical in high-precision industries such as aerospace, medical device manufacturing, and microelectronics. One of the E-Chuck’s most innovative features is its ability to rotate endlessly around its own axis. This continuous rotation not only enables seamless access to all sides of a part but also supports the machining of complex geometries with unprecedented ease. Whether dealing with multi-faceted surfaces or intricate 3D contours, the E-Chuck ensures optimal accessibility and positioning accuracy.
Hall 9 Booth 9504Â Â For more information: www.maprox.ch
Thread Inspection of The Future
MultiCheck 4.0 is a system for automated thread measurement, offering fully automated gauging and testing of threads, as well as thread depth measurement. It’s designed for use in production environments, ranging from inline applications to autonomous measuring cells, with options for gauge changers and measured value transmission. The system can check thread accuracy and depth, including GO and NOGO testing. The system can measure thread depth up to 4 times the thread diameter, with a maximum of 50mm. The system can handle a range of thread sizes from M5 to M20, as well as both right and left-hand threads.Â
Mahr To Present Comprehensive Scattered Light Inspection PortfolioÂ
With the acquisition of OptoSurf, Mahr has sustainably expanded its portfolio to include scattered light technology. By implementing the OptoSurf portfolio Mahr is opening up new opportunities in the field of tribology. Ball screw drives are used to convert rotary motion into longitudinal motion such as in machine tools and steering systems. Particularly in the latter, efficiency, wear and possible noise development depend heavily on the surface quality of the ball tracks. This is where the OptoRack measuring machine from Mahr comes into its own. MarSurf3D OptoRack was specially developed for process monitoring during the grinding and finishing of racks and ball screws. Due to a swivel axis, the sensor can measure the roughness and waviness separately on paths to the right and left of the pressure point of the raceways at any point on the spindle.
Hall 3 Booth 3104Â Â For more information: www,metrology.mahr.com
