3D Scanning Sensor With Large Field of View Launched
Automation Technology is expanding its cost-efficient ECS series with the new ECS 4090 3D sensor, which has been specially developed for applications in the food and logistics industries as well as for robot vision. The ECS 4090 impresses with its significantly larger field of view of either 284 mm, 575 mm or 1020 mm (available soon), making it ideal for a wide range of applications.
The ECS 4090 also offers twice the pixel resolution of the previous 2040 model, which enables greater precision while maintaining the same accuracy. And thanks to its class 2M laser (660 nm), the ECS 4090 can also be used and operated without any problems or special laser protection measures.
By supporting standard interfaces such as GenICam and GigE Vision, the ECS 4090 can be seamlessly integrated into existing systems and is also a real benefit for customers due to the firmware developed by AT. The software that comes with the ECS 4090 has numerous features that enable precise and efficient data evaluation.
The ECS 4090 is designed as a 3D sensor for every budget, combining outstanding performance with a cost-efficient design. It is precisely this combination that provides the ideal solution for demanding applications where the customer does not want to compromise on precision and safety.
For more information: www.at-sensors.com
