3D Laser Scanning Sensor Measures High-Performance Tools
Walter Ewag has launched the Walter 3D laser sensor enabling the Walter Helicheck Pro and Plus tool measurement machines to scan with four times the resolution than previously possible and to process that data four times faster.
The Walter 3D laser sensor is suitable for inspecting high-performance tools, used in industries such as automotive, aerospace and medical, where cutting edge geometry, pitch and spiral pitch vary widely. The company says its 3D sensor could replace two separate machines traditionally used for measuring such tools.
The 3D sensor has swivel angle ranges from -55° to 90° to enable scanning of indexable inserts. It is available as an option on the Helicheck Pro and Plus machines and their corresponding Long versions, which can accommodate tools up to 80 mm diameter and 605 mm long.
Walter 3D laser sensor is designed to be easily and quickly programmed using wizard routines, enabling shorter setup times. The 3D sensor effectively visualizes the workpiece as a point cloud enabling measurements to be performed on the three-dimensional image.
When the resulting image is ‘located’ on the tool’s 3D design drawings, or a master part, any deviations can be clearly seen via the integrated 3D Viewer as three-dimensional comparisons of point cloud and target model – including surface reconstruction.
For more information: www.walter-machines.com
